Old 10th January 2014, 22:04   #106
Thanked: 528 Times
Default Re: Forester Owners: Servicing?
Originally Posted by gotzuk View Post
That's a nice price since the shipping is free.
I will be ordering mine shortly.
Thanks again!
Free shipping would be just within USA.
Guna is offline   Reply With Quote
Old 10th January 2014, 22:50   #107
gotzuk's Avatar
Thanked: 66 Times
The option doesn't show up when viewing the item. However, once you add to cart and checkout, they offer free global shipping option and billing in INR.
gotzuk is offline   (1) Thanks Reply With Quote
Old 27th January 2014, 13:48   #108
gotzuk's Avatar
Thanked: 66 Times
Update:
Amazon's Global Saver indeed works.
The Exedy kit was delivered today sans any extra charges.
Forester Owners: Servicing?-imag0052.jpg
gotzuk is offline   (2) Thanks Reply With Quote
Old 31st January 2014, 23:08   #109
Thanked: 528 Times
Update:
Does this kit include Clutch plate, pressure plate and release bearing?
Have you got it installed? How does it feel?
Old 1st February 2014, 00:28   #110
gotzuk's Avatar
Thanked: 66 Times
The kits contains the clutch plate, pressure plate, release bearing, pilot bearing, centering tool (plastic) and a small tube of grease.
It has not been installed yet as I am still waiting for the Group N transmission mount and pitch stop mount to come in.
Also changing out the shifter bushes to COBB polyurethane units along with a COBB short shifter
I am hoping to get it all installed in a fortnight or so.
gotzuk is offline   Reply With Quote
Old 1st February 2014, 10:22   #111
Thanked: 528 Times
Interesting. Do you think this will eliminates the 'notchy' feel of the Forester gear?
Old 1st February 2014, 10:59   #112
gotzuk's Avatar
Thanked: 66 Times
It should. There is not much apart from them to lend slop to the gear linkages.
I will be changing out the front shifter bushing (20) and rear shifter bushing (30) with COBB units.
Forester Owners: Servicing?-583494935001.png
Old 5th February 2014, 10:11   #113
WRXXX's Avatar
Thanked: 290 Times
would this also help in getting the gear shifts better?
I was always apprehensive about these
http://www.subarugenuineparts.com/pr...roducts_id=707
Would love to know how your mods go.
WRXXX is offline   Reply With Quote
Old 5th February 2014, 11:01   #114
gotzuk's Avatar
Thanked: 66 Times
A short shifter will only affect the shift lever throw and in fact more force will be needed to slot into gears due to reduced leverage.
It's the linkages and bushes which improve the shift quality.
I already have the COBB Short shifter and it is adjustable for both height and throw. Let's see how it goes.
Forester Owners: Servicing?-1391578281924.jpg
Old 5th February 2014, 12:11   #115
WRXXX's Avatar
Thanked: 290 Times
Good stuff! Will be staying tuned for an update.
Old 24th February 2014, 17:32   #116
Thanked: 528 Times
During the recent service at Trident Chevy, they have suggested me to replace the clutch (along with few other things!). Since it feels quite heavy, SA feels I need to replace the clutch plate, pressure plate and release bearing.
But can a worn out clutch make it feel heavy to operate? I thought it isn't connected as the light/heavy depends on the hydraulic assistance, lubrication etc.
Following are the 'symptoms' on my car's clutch
  1. Considerably heavy/tight
  2. First half or more of the pedal travel doesn't do anything (disengaging)
  3. Car can actually crawl near zero speed without jerking
  4. Sometimes I feel the engine labors more then necessary to get the required speed
  5. FE of around 6.75 kmph in the city
  6. Slight jerk when I release the clutch during shifting
Experts, pls comment if you think these are sins of a worn out clutch?
Old 25th February 2014, 10:29   #117
gotzuk's Avatar
Thanked: 66 Times
Worn pressure plate fingers will cause the pedal to become hard and also cause the engaging/disengaging
to happen over a shorter travel play, which could cause jerking while releasing the clutch due to sudden engagement.
The fuel consumption and acceleration should not be affected unless the clutch is worn out enough to slip under load.
Apart from checking the regular items (plugs, filters, throttle body clean) also look at the O2 sensor.
A failing O2 might not throw a CEL but still cause low power and increased fuel consumption.
Does your car idle OK?
Old 25th February 2014, 16:47   #118
Thanked: 528 Times
I have not felt it slipping under load. Probably the pressure plate is gone. In any case I have decided to replace it and I have gone ahead with the order.
@gotzuk, have you come across any alternative solution for struts replacement? With the KYB one has to replace the springs as well which makes it expensive and complex (apparently some springs are pig tailed at top some are chopped, which may lead to compatibility issues)
Old 26th February 2014, 01:03   #119
gotzuk's Avatar
Thanked: 66 Times
The self leveling rear struts have a shorter spring than the regular strut.
So when swapping out to any non self leveling unit a matching spring is also needed.
A set of 4 KYB GR2's are about $400 on eBay and OEM springs for the rear are around 70 each.
Add shipping and import duty and I reckon they would cost a little over $900 delivered here.
OTOH, the Tokico self leveling struts alone cost around 60k plus for a pair and Tokico fronts were around 17.5-20k last I checked.
Old 26th February 2014, 09:50   #120
Thanked: 528 Times
I believe these springs are also softer (less firm) as the self leveling struts itself takes part of the load.
All Laura Owners and Accord Owners, Please stand up personified Sedans 9 11th December 2008 17:09
Spotted Subaru Forester & "Chevy Forester" in Hyderabad midlifecrisis The Indian Car Scene 14 26th October 2007 12:29
Chevy nee Subaru Forester Revvmaster The Indian Car Scene 27 15th July 2005 22:29
why did the CHEVY FORESTER fail in india?? Aloking The Indian Car Scene 2 16th May 2004 11:22
For all you Subaru Forester Fans GTO The International Automotive Scene 10 6th March 2004 15:00
