Old 29th October 2009, 11:00   #16
shazikon's Avatar
Thanked: 19 Times
To isolate wheel bearing issues, hosit the car. rotate the wheel by giving it a quick torque. keep your hand on the lower swing arms or the lower suspension member. if you can feel vibration then, bearing is worn out! you may or may not hear a grinding noise especially when driving at a particular speed.
shazikon is offline   Reply With Quote
Wagon R - Rear wheel bearing broken Swift Technical Stuff 18 5th November 2013 18:29
Machismo 350 AVL Technical Specs - Engine Oil, Clutch and Gearbox Amount and Specs imbue Motorbikes 1 26th April 2011 19:59
Honda Recalls 182,756 Civics Over Wheel-Bearing Leak Ashutosh The International Automotive Scene 11 18th September 2007 11:16
