Thread Tools
Old 12th April 2005, 12:16   #1 (permalink)
speedsatya's Avatar
Default new tires:FE up or FEdown????
guys,
when tires get worn off,the traction offered by these worn tires decrease with every km.
as a result the grip offered will also be lesser.
so theoretically,the FE should increase .
and when u fit new tires of the same size,the grip offered is better .which should mean lesser FE due to improved traction.
but we see everyone saying that their FE has improved after fitiing new tires of the same size.
is this possible????????
satya
speedsatya is offline   Reply With Quote
Old 12th April 2005, 13:14   #2 (permalink)
veyron1's Avatar
on the contrary satya, F.E actually decreases due to worn tyres, as worn tyres have smaller circumference, due to which the overall rolling distance decreases, thus resulting in decreased efficiency;plus, the worn tyres mean that while driving on highways, the traction decreases, and the slip between the tyre and the road increases-meaning the engine has to rev more to produce the same speeds, as against new tyres.
all the same, your in city or low speed (say, upto 40-45 km/h) F.E should go up slightly, as the engine has lesser friction from the tyres to cope up with, which means lesser resistance to move the car.
new tyres definitely aid in the overall dynamics of the car, not to mention grip, cornering abilities, and overall F.E.
but it also depends upon which tyre size you go in for; if you're running stock tyres of, say,165/70 R13, your F.E., ride quality, and handling will increase if you go in for 185/70 R13; also, if you go in for 185/65, you'll get better handling as compared to both the said tyres, but F.E. will be lesser than the 70 profile (185); also, you'll get lesser ride quality.
__________________
DAD
veyron1 is offline   Reply With Quote
Old 12th April 2005, 13:21   #3 (permalink)
speedsatya's Avatar
Originally Posted by veyron1
as worn tyres have smaller circumference, due to which the overall rolling distance decreases, .
hey,
less rolling circumference means less rubber on the road .which in turn means less resistance the engine.so shouldnt the FE go up????
also less circumference means greater speedo error,which in turn will show slightly more kms on the odo and the speedo.
so here also u should get higher figures.
and i am not talking abt upsizes.i am talking abt a new tire of the same size.
Old 12th April 2005, 15:09   #4 (permalink)
Shan2nu's Avatar
hey,
Smaller circumference means less distance per revolution. So, you're engine will actualy be revving a little higher at 100 on worn out tyres when compared to new ones. Higher rpm equates to higher fuel consumption and even when you calculate your kmpl, the new tyre will take lesser revolutions to complete the km than a worn out tyre.
And lastly. Rolling resistance is dependant on a lot of factors. A 19/60 R14 S322 could have a higher rolling resistance than a 195/60 R14 GIII or F1 Eagle. i'm not saying that is the case but it's very possible.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Shan2nu is online now   Reply With Quote
Old 12th April 2005, 15:56   #5 (permalink)
speedsatya's Avatar
yeah so that means ,the odo reading will be more than that of a tire which is neweras it will have greater circumference.this difference will be negligible,but it will be difffernt.
or can we say that the engine will burn less fuel to reach higher revvs on a worn tire.
i am not talking abt a completely worn tire.
so a brand new tire may offer better grip ,but at the same time its gonna consume more fuel to reach the same revvs. than on a more worn tire.
so i cannot understabd as to how do people claim to get better FE on newer tires.
Old 12th April 2005, 16:29   #6 (permalink)
Shan2nu's Avatar
A grippy tyre need not necessarily have a higher rolling resistance. Tyre design plays a major role in it. Even my 195mm GIII roll much freely than the worn out S322s did.
Shan2nu
__________________
Old 12th April 2005, 19:38   #7 (permalink)
Vulken Auto's Avatar
wont the tires spin if they dont have grip hence loosing lots of power . so fuel taken from point A to point B should be more.one more point
There are lot of factors involved here. exactly dont know which plays more role. I think mileage increases with new tires and it fells good abt the car.
__________________
One of the things we know is, It's not how stand by your car, its how you race your car.
--Jarule
Vulken Auto is offline   Reply With Quote
Old 13th April 2005, 01:48   #8 (permalink)
gamerno1's Avatar
Originally Posted by speedsatya
guys,
satya
in my case, the FE has gone up hugely by 1.5 - 2 kms
__________________
- INFECTED
8 months!
gamerno1 is offline   Reply With Quote
Thread Tools
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 8 15th January 2008 01:56
Tires for the Esteem prince85 Tyre & Alloy wheel Section 7 11th August 2006 17:37
TOYO Tires adit1329 Tyre & Alloy wheel Section 11 11th February 2006 00:22
What is it with wheels and tires? Selective Tyre & Alloy wheel Section 7 25th June 2005 00:24
Do I Need a Change of Tires? gamerno1 Technical Stuff 14 2nd March 2005 23:46
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
