Old 7th May 2014, 10:23   #46
dj78's Avatar
Thanked: 59 Times
Default Re: Roughness in Body Paint.
After some research on several threads and other online sources I have ordered the Bilt Hamber clay (also because Meguiar's is currently not available and the entire Kit costs a bomb at around 4.5K).
Ordered it on ebay through detailedclean.in - http://www.ebay.in/itm/Bilt-Hamber-A...bebc180&_uhb=1
I had an ebay coupon so it worked out a tad bit cheaper than ordering directly on the website.
Bilt Hamber claims that the clay is designed to be used with tap water and does not need any lube.
So anyways waiting for the shipment to arrive and would revert with the results.
dj78 is offline   Reply With Quote
Old 22nd May 2014, 10:37   #47
dj78's Avatar
Thanked: 59 Times
Apologies about the delayed update but the clay treatment did the trick. Whatever the surface contaminant was seemed to come of magically as I rubbed the clay one panel at a time - At the end of it the surface was as smooth as new. I followed it up with a treatment of Formula 1 Carnauba wax. It was a 4+ hour job and the hot day did tire me out but the end result was satisfactory. I would definitely recommend Bilt Hamber to anyone who has a similar need.
A Fiat 500 Abarth made from human body & body paint dharmeshmahajan The International Automotive Scene 5 25th October 2013 14:47
Help!! how to remove super glue from body paint kanva Modifications & Accessories 12 15th November 2010 11:02
Dent on the body - Will the paint peel off if I repair it? ankura12 Technical Stuff 16 27th January 2008 13:52
paint over paint DRC Technical Stuff 33 25th August 2006 12:05
What a paint job..S2000 with Clear Paint.. _Crazi4Speed_ The International Automotive Scene 6 20th September 2004 23:44
