Old 7th December 2008, 15:12   #1
Sowmya's Avatar
Thanked: 16 Times
Default Roughness in Body Paint.
I had given my car for service few days back and it is back. Today while I was washing my car I felt that Some of the portion of the Car Body has became rough. Even in the Wind Screen became rough. As if some another kind of layer is coated from out side. Dont know what to do ?
Sowmya is offline   Reply With Quote
Old 7th December 2008, 15:34   #2
white_vdi's Avatar
Thanked: 18 Times
go back to the service center and ask them to clean it properly. your car must have been parked near the paint dept. They will use 1500 or 2000 no. emery paper and sand it lightly. No harm done.
white_vdi is offline   Reply With Quote
Old 7th December 2008, 17:29   #3
Sowmya's Avatar
Thanked: 16 Times
Yes, I think so. Becos my Car had gone to Painting work. Those stupid service people made a big scratch on my car while I gave for Servicing.
Old 7th December 2008, 17:46   #4
white_vdi's Avatar
Thanked: 18 Times
then i am sure that it is paint n clear on your car. just go back n ask em to rub it out. nothing much
Old 7th December 2008, 18:02   #5
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Yup, it's paint that has settled on your car causing this.
Once i my building someone was getting some furniture polished in his garage and clear melamine polish had settled on my car. A cloth slightly moistened with thinner solved my problem.
Go with white_vdi's suggestion for paint smoothening. For the windscreen, use a thinner.
Tejas@perioimpl is offline   Reply With Quote
Old 7th December 2008, 21:05   #6
Sowmya's Avatar
Thanked: 16 Times
Oh !!! Furniture polished also ca do some thing like this ? Then how did you removed them ? Today I drove the car after washing. Felt like crying. Wind screen is completely blurred. but While I tried to remove those with nail its is going easily
Old 7th December 2008, 22:09   #7
just use a cloth moistened with paint thinner or nail polisher remover (acetone) for your windscreen. Will remove the roughness like a dream!
Keep us posted on your experience...
Old 7th December 2008, 22:37   #8
autopsyche's Avatar
Thanked: 15 Times
The car must have been close to another car being painted, the clearcoat overspray has settled over your car. Take it back to the workshop and tell them to clean it up, it will involve roughing it down with emery paper and then buffing the panels. Cleaning only with thinner wont do much because in all probability the spray was premixed with an accelerator catalyst which hardens over time and is difficult to remove.
autopsyche is offline   Reply With Quote
Old 7th December 2008, 23:28   #9
Your right. Thinner only for the windscreen which you can't sandpaper.
Old 7th December 2008, 23:45   #10
androdev's Avatar
Thanked: 2,305 Times
be ready for a car with all sanding marks though. i have never seen any workshop restore factory finish no matter what others claim - even when handsomely paid.
androdev is online now   Reply With Quote
Old 8th December 2008, 02:22   #11
white_vdi's Avatar
Thanked: 18 Times
there are no sanding marks left. i got the same done on my car and there were no marks or anything after the procedure. you need to do it with a very light hand and its no big deal.
Sowmya is perfectly safe dont worry.
Old 8th December 2008, 08:43   #12
autopsyche's Avatar
Thanked: 15 Times
I agree with that, dont worry, if properly buffed there would be no sanding marks left. Thats standard procedure even when your car gets repainted completely and is a safe option.
Old 8th December 2008, 09:36   #13
This is not the regular brown sandpaper used by carpenters. Emery has a very fine grit and is used world over for final smoothening of any surface just prior to buffing. 3M fine emery is recommended. No harm done to paint.
Just for info from Wiki:
Emery paper is a type of paper that can be used for sanding down hard and rough surfaces. It can also be used for resistant technology purposes to give a smooth, shiny finish to manufactured products and is often used in the finishing of high-end watch movements. Similar to sandpaper, it is made by gluing small particles of the mineral emery (also called iron spinel or hercynite) to paper.
Old 8th December 2008, 20:19   #14
Sowmya's Avatar
Thanked: 16 Times
I believe this paint is not a normal paint. Its a burnish paint. I think some one was doing Furniture working and sprayed all over.
By the way any Idea how to remove this Burnish ? If I try to remove the thiner in the Body will this effect the Body paint ?
Old 8th December 2008, 20:32   #15
Yes, burnish can be removed with a thinner or nail polish remover (acetone).
I don't think thinner will affect the car paint. What you can try to do is, that take some thinner on a cloth and apply it to some part of the paint inside the bonnet (or somewhere where it is normally not visible) and scrub it vigorously to check if paint is not affected. Recheck after couple of days and if there is no change, then apply it elsewhere with a cloth. Wipe with water later.
You can use it on the windshield confidently though.
A Fiat 500 Abarth made from human body & body paint dharmeshmahajan The International Automotive Scene 5 25th October 2013 14:47
Help!! how to remove super glue from body paint kanva Modifications & Accessories 12 15th November 2010 11:02
Dent on the body - Will the paint peel off if I repair it? ankura12 Technical Stuff 16 27th January 2008 13:52
paint over paint DRC Technical Stuff 33 25th August 2006 12:05
What a paint job..S2000 with Clear Paint.. _Crazi4Speed_ The International Automotive Scene 6 20th September 2004 23:44
