Old 15th May 2014, 18:13   #16
ecosport rules's Avatar
Thanked: 1,351 Times
I had Hyundai charging me for it. Then once I got my Santro serviced outside, and found that extracting the Injectors took an hour. So I guess the HASS was just ripping me off.
On the other Honda advise against this, unless strictly necessary, in fact the GM advised against it since you will abrade and open the jet holes.
Thank you for the clarification. It is more of a rip off than any benefit I guess. Does the owners manual of your Honda mention about injector cleaning in the maintenence schedule?
ecosport rules is offline   Reply With Quote
Old 15th May 2014, 19:45   #17
humyum's Avatar
Thanked: 2,503 Times
Default Re: My Fuel injector cleaning with carbon clean
I have never touched my injectors in 93 thousand of my cars life. No Clean, no remove, nothing. Don't touch something which is not broken.
Go for a long highway blip once in a while and you won't need all this injector, egr vgr cleaning.
Old 15th May 2014, 20:36   #18
+1
I am following the Italian tune up system and will keep an on the job card while being written so that the injector cleaning is not done.
Advice needed on Injector cleaning nitindangoria Technical Stuff 63 26th December 2013 16:05
Injector cleaning in mumbai Rice_tuner Technical Stuff 8 1st November 2008 13:08
Injector Cleaning Fluid n_aditya Modifications & Accessories 12 20th March 2006 16:40
