Old 8th December 2008, 20:24   #16
Sprucegoose's Avatar
Thanked: 40 Times
Originally Posted by nitrous View Post
Revv the engine a bit when this occurs, and check if you're gaining some braking efficiency.
Most probably,its the booster or leaking vacuum hose.
the Brakes do seem to be slightly stiffer when i revv the engine..
Sprucegoose is offline   Reply With Quote
Old 2nd March 2009, 19:34   #17
ralstonraz's Avatar
Master cylinder is the issue. Expensive part to replace, but that is the root cause of the issue.....
Time to spend some bucks Shekar...
ralstonraz is offline   Reply With Quote
Old 10th August 2011, 12:21   #18
gou
gou's Avatar
Default Re: OHC Brakes Failed
Shekhar,
Did you find the solution to your problem? I faced similar problem in my OHC yesterday.
gou is offline   Reply With Quote
Old 10th August 2011, 16:42   #19
Thanked: 40 Times
Originally Posted by gou View Post
Shekhar,
Old Thread...
Replying on your one.
Royal Enfield Thunderbird 500 : Brakes Failed : No Quality Control shan2129 Motorbikes 45 21st April 2016 11:24
Ohc 1.5 Vs Ohc Vtec narayan Technical Stuff 137 24th January 2015 12:15
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 5 22nd June 2012 17:00
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Bolero brakes failed - fixed. Now its not the same. Spinnerr Technical Stuff 12 4th February 2009 12:17
