Old 14th April 2005, 15:38   #16
also what is the fuel level in the vehicle...is it very near the empty mark?
adilshah is offline   Reply With Quote
Old 14th April 2005, 16:32   #17
hey buddy..these new generation cars come with very sensitive fuel pump's and you should go get that checked at an official ford service centre..well it could be a basic fule pump failure which is undetected by the local mechanice it could also be some dirt on the fuel pump..or a choke in the fuel pipe..well also do make sure in the future dont drive the new-gen cars in resreve..because the fuel pumps are very sensitive and to much load on the pump to drive the fuel inot engine may lead to failure of the pump...so anyways that was my bit that i could give you...if you need any other help please feel free to pm me...cheers...!!
dragger is offline   Reply With Quote
Old 14th April 2005, 17:46   #18
SUV
SUV's Avatar
Default Fule Cut off Solenoid
hey Guy's ...
Doesnt the Ikon have a Fuel Cut Off Solenoid .. Guess it would be worth to check the Solenoid .. cos if the car is cranking and the fuel supply is good then guess thr is something else blcoking the fuel flow
Just thinking aloud ..
SUV is offline   Reply With Quote
Old 14th April 2005, 18:04   #19
bhp
bhp's Avatar
Thanked: 152 Times
Originally Posted by tsk1979
Hey bhp when your car shuts down, do the revs climb up on their own always? If thats the case it could mean the timing belt or timing mechanicals are faulty.
thanks a lot guys for the help .
my car is a oct 2000 model . and when my car shuts down the revvs do not climb up at all .
i have to check cleaning up the fuel pump may be and then willl let u guys know and tomm i am getting my car towed to the service station
bhp is online now   Reply With Quote
Old 21st April 2005, 11:41   #20
bhp
bhp's Avatar
Thanked: 152 Times
guys i had send the car to the service station and they said it is the problem with the ecm unit . it is costing me 40k with taxes and labour . wat should i do helpppppppp
go for the og ecm or get a stand alone fuel management system .
how much will that cost and where shall i get it for a ikon
Old 21st April 2005, 11:58   #21
ZenGT's Avatar
hey bhp..
has the ecm died... if not why dont u get it repaired.... at least try... might save a hell lot of money...i can get that done for u
well if u already plannin to put in the new ecm .. i would suggest go in for a stand alone... will cost u almost the same price of the original ecm....
all the best..
ZenGT is offline   Reply With Quote
Old 21st April 2005, 13:19   #22
iceman91's Avatar
Thanked: 22 Times
yeah bhp, first try to get the ecm repaired in some aftermarket shop. then try to buy a used ecm from the aftermarket.
car is more than 4 years old..how long you plannig to keep it? if for long then buy a stand alone engine management. if planning to sell it soon get it repaired
iceman91 is offline   Reply With Quote
Old 21st April 2005, 14:09   #23
dev
Guys,
I am scared now. I have Ford Ikon 1.3 CLXI. 2001 make.
I got it for 3lakhs and after hearing this cost of 40K, I am scared. This vehicle is the first one for me and I did not took it outside as I am not used to this city conditions.
Need to learn fast.
Bhp,
let me know what u have decided. And any other problems u met with Ikon? I will get prepared from now.
Iceman,
Do u know anyone who can teach me on this Ikon? I know there are lots of Driving schools. Still I prefer a person who is known and can take me to busy streets and I want to learn in one day(fast track. looks silly?)
And also any good dealer for LPG kit?
Thanks.
dev is offline   Reply With Quote
Old 21st April 2005, 14:19   #24
iceman91's Avatar
Thanked: 22 Times
dev would love to teach you but at teh end of it either i will kill you or your car will be a wreck!!!
i have no patience i am sorry.
best is to learn with the driving school and then keep driving...
Old 21st April 2005, 14:29   #25
dev
Thanks Iceman. I had a driven this vehicle in non-conjusted roads. I need to learn reversing this big vehicle and learning in the busy roads like MG road, Airport road.
-thanks
Old 21st April 2005, 14:47   #26
iceman91's Avatar
Thanked: 22 Times
the best way to do it is practice and keep practicing....because when it comes to driving no one is perfect. also as you said you just bought it recently you will feel uncomfortable it is natural!!!
all the best and drive safe
Old 21st April 2005, 15:51   #27
Thanked: 11,106 Times
Originally Posted by bhp
guys i have a very very serious problem with my ford ikon 1.6 . the problem is that when i give it a self the car starts up but after 2-4 seconds the car turns off even after hard acceleration .
Cannot understand what exactly you mean but
Could be something simple like defective plugs and leads
Check the Mass Ari Flow Sensors - chances are that they are dirty, causing less petrol to be injected - shutting down the engine
Old 21st April 2005, 15:54   #28
iceman91's Avatar
Thanked: 22 Times
ajmat sir he got it all checked and the ford as well as aftermarket guys said that the ecm is the cause of it
Old 22nd April 2005, 19:32   #29
gr8guzzler's Avatar
Thanked: 38 Times
Hey BHP....I'm getting a similar problem....only that my car stalls for a few times on a cold start and then everything is fine. I went to Wasan ford and they replaced a sensor which they said was faulty but today morning again had the same problem. Any suggestions on how to rectify this....
gr8guzzler is offline   Reply With Quote
Old 23rd April 2005, 15:17   #30
Ford Rocam's Avatar
Thanked: 16 Times
Hey BHP,
it Seems to me that the problem is not with the ECM, The ECU used in ikon is latest Generation Bosch EEC V ECU , I have opened and seen the ECU its a very Small PCB 4"*5" inch highly insulated and no serviceable parts inside, If ECU had a problem the car would not have started only, When u start ur Engine THe ECU takes lots of Feedback from different Sensors like CPS, CKS, (camshaft position sensor/Crank position sensors ) it uses this sensors feedbak to determine position of Pistons, valves open/close The Problem could be with these sensors, when the ecu dosent get the feedback its not able to determine position of pistons and firing order and hene it stalls, the problem could be also due to wires carrying sensors signal to ecu if it has eaten by Rat which is a rare chance but possible you an ask the mechani c to check the continuty of wires with meter, Some times big problems are solved by simple solutions
Ford Rocam is offline   Reply With Quote
Problematic Gear boxes in Fiesta 1.4 EL? Venkatesh.C The Indian Car Scene 9 16th November 2007 09:46
A Problematic Free-Flow !!! dustDevil Technical Stuff 10 29th June 2006 22:57
Most Problematic Cars Sahil The International Automotive Scene 26 8th September 2005 00:04
problematic indigo akshaybadia Technical Stuff 5 9th June 2005 11:33
