| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | guys i have a very very serious problem with my ford ikon 1.6 . the problem is that when i give it a self the car starts up but after 2-4 seconds the car turns off even after hard acceleration . i had called up a couple of mechanic s and nobody could just rectify the problem . they checked everything right from all electric stuff to mechanical stuff they even checked the fuel pump many a time s . both the mechanic said that there could be a problem of the ecm box and one of them has taken the ecm box to be checked upon . the mechanic said that if that is a problem it cannot be repaired and has to be replaced with is quite expensive help
__________________ 05 suzi baleno 07 city vtec 08 swift DDIS Live Life in the Fast Lane "vvvrrrooooommmmmmmm" |
| | #2 (permalink) |
| BHPian Join Date: Jan 2005 Location: Hyderabad
| did you go to authorized ikon workshop?? they will give you correct answer, if its not in warranty take an extra warranty if possible.
__________________ One of the things we know is, It's not how stand by your car, its how you race your car. --Jarule |
| | #5 (permalink) |
| BHPian Join Date: Jun 2004 Location: Mumbai
| spark plugs get them checked....or injectors have to be cleaned ..i doubt it is a fuel pump prob....i strongly suggest that u check your electricals
__________________ YoUr CaR DoEs NoT HaVe a BrAiN, So iT's DoUbLy ImPoRtAnT YoU UsE YoUrS. |
| | #6 (permalink) |
| BHPian | Even I have a feeling its a problem wid the ecm unit...and if it is dude u are in grave problem!!!unless its still running under warranty...Also chk the electronics,,may be some capacitor,coil problem.
__________________ I cried coz I had no turbo, till I met a man who had no VTEC!!! |
| | #7 (permalink) |
| BHPian | no my car is not under warranty and every other think is checked and now the ecm box is to be checked . if the ecm box has a problem then it is going to cost a bomb say some 25-30 k in the local market
| | #9 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: Mumbai
| Quote:
He Bhp I suffered the same problem some years back there was bit of dirt on the fuel pump.
__________________ F50 14 | |
| | #11 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| take it to a ford authorised service center instead if relying on zillions of door step mechs and if its ecm and under warranty u will get a free replacement..
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #14 (permalink) |
| oops i read it wrong.. lol... either ways get it checked by authorised guys (worth it), i wouldnt risk my cars with local guys.. it can be as simple as a failed ignition coil or coil wire also.. the ecm cars are funny when it comes to trouble shooting..
| Thread Tools | |
Similar Threads | ||||
| need help regarding ford IKON | dapinderjit | Technical Stuff | 3 | 2nd June 2008 16:21 |
| Ford Ikon mod - fiesta head on ikon block? | madhunm | Modifications & Accessories | 2 | 2nd July 2007 09:24 |
| the ford ikon 1.6 | le_doctor | Modifications & Accessories | 13 | 5th May 2006 23:01 |
| Ford Ikon 1.6 at 5.4? | RX135 | Sedans | 3 | 12th January 2005 18:30 |
| Ford Ikon | v12 | The Indian Car Scene!! | 1 | 24th February 2004 10:35 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
help
