Closed Thread
Old 11th December 2008, 10:31   #1
bill1182's Avatar
Default Swift Vxi Idling Problem
Since 2 days I have noticed a very wiered behaviour with my car. With AC on the RPM goes up to 1500 in idling condition it comes down to 850 and again goes back to 1500 immediately. This keeps on happening till the vehicle is idling.
With AC switched off, the RPM goes up to 1200 RPM (hot engine) and then dropps to around 400 RPM. Engine starts vibrating a lot and I have to press the gas peddal to keep the car running.
Need some help on this problem from the Gurus. What could be the issue. Is it an ECU failure? I showed it to MASS today they are telling it is some problem with the Butterfly in Trottel Body and some problem with the Injectors. I am not satisfied with their answer.
Also they want me to pay for cleaning the same even thouth the car is in warranty.
Please help me guys.
bill1182 is offline
Old 20th July 2011, 18:09   #2
sushir's Avatar
Default Re: Swift Vxi Idling Problem
These threads might help ...
http://www.team-bhp.com/forum/techni...g-problem.html (M-800 mpfi idling problem.)
http://www.team-bhp.com/forum/techni...ing-issue.html (Engine Idling Issue)
http://www.team-bhp.com/forum/techni...in-idling.html (Corsa 1.6 cannot maintain idling)
I am facing the same issue with my A-star Automatic ... Planning to go to MASS right now.
sushir is offline
Old 20th July 2011, 21:21   #3
Thanked: 141 Times
If the injectors functioning are in doubt then first attempt try out System G (for Petrol) available at Bharat Petroleum bunks. To a large extend, extensive noise, idle behaviour etc have improved for many who have used the System G, including me (on my Honda City though). I would suggest try that out first (usually effect will be visible in the first 100 KM of usage), before heading to servicing centers
narayanang76
narayanang76 is online now
Old 20th July 2011, 22:31   #4
Thanked: 660 Times
How old is your car. How much kms done. How is the car under normal conditions, i mean in motion, in gears.
If its smooth then injectors are out of question. check the air sensor and its related wiring.
SirAlec is offline
Old 20th July 2011, 22:34   #5
Eddy's Avatar
Thanked: 5,069 Times
Guys, its almost a 3 year old thread.
Eddy is offline
Closed Thread
Problem with Vtec idling...varying RPM. EDIT : Solved! GTO Technical Stuff 99 22nd January 2017 16:48
Engine Idling Problem KSM-Vtec Technical Stuff 53 29th May 2016 00:46
Starting and idling problem in Carb Zen archat68 Technical Stuff 30 28th March 2014 14:37
Idling varies in Swift VXi redfire Technical Stuff 3 7th February 2008 16:02
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 11:19
