Old 24th May 2005, 15:01   #31
DueLLeR's Avatar
Thanked: 61 Times
Technocrat,
Both Esteem and Baleno feature HPS and NOT EPS. Not sure about Scorpio. OHC has HPS and NHC has EPS.
About the Baleno, from http://baleno.marutiudyog.com/tech_chassis_main.asp
Steering: Rack and pinion with hydraulic power assistance
Brakes
Type: Vacuum assisted hydraulic
Front: Ventilated Disc
Rear: Drum, leading / trailing
Suspension
Front:Mc Pherson strut & coil spring with an L shaped lower arm and anti roll bar
Rear:Mc Pherson strut & coil spring with parallel link arrangement
Tyres:165/80R13
Cheers!
DueLLeR is offline   Reply With Quote
Old 24th May 2005, 16:31   #32
Technocrat's Avatar
Thanked: 2,477 Times
Oh, somehow I always thought that the Baleno had EPS.
Anyways, Thanks for correcting me
Old 24th May 2005, 17:00   #33
greatDrive's Avatar
What about Fiat Cars? Are they HPS or EPS?
greatDrive is offline   Reply With Quote
Old 24th May 2005, 17:02   #34
Thanked: 32 Times
Palio and Petra have HPS.
deepakhon is offline   Reply With Quote
Old 2nd August 2005, 18:02   #35
shuvc's Avatar
Thanked: 283 Times
Default Convert non-PS to PS
Is it possible to fit power steering on a non-PS car ?
And if so, would the cost be prohibitive ?
Old 2nd August 2005, 18:32   #36
If you search the archives on the indica-users Yahoogroup, you'll find that one member has retrofitted power steering on his 1999 V1 DLE.
The archives are currently down but I'll try and get the person's email address for you. As well as the other details.
This member is a 71 year old gentleman who "indulged" himself with power steering recently. Remember, when he bought his DLE, the only model with power steering was the DLX!
hrag
hrag is offline   Reply With Quote
Old 2nd August 2005, 20:10   #37
pranil's Avatar
I find on my fathers ALTo ( vx 1.1) the EPS is bit less sensitive in 0 to 15 deg area. e.g. when driving on highway when you do gradual lane change the EPS does not return to centre zero but you have to bring it back. I was driving a Toyota Carina ealier with EPS and never noticed this. I felt the same problem during swift test ride although the EPS is shifted from Engine bay to steering rack.
anybody has similar experience
pranil is offline   Reply With Quote
Old 2nd August 2005, 20:45   #38
speedsatya's Avatar
Thanked: 706 Times
Originally Posted by Technocrat
Very nicely put
Btw baleno was the 1st maruti car to have EPS. It came later in the Wagon R & the Alto Vxi
M.
the euro-2 zen vxi in 2000 was the first maruti to have mpfi as well as eps.
baleno and the esteem have hydraulic PS.
the EPS in the maruti small cars cut off above 60kph.
speedsatya is offline   Reply With Quote
Old 3rd August 2005, 11:20   #39
Technocrat's Avatar
Yeah I came to know about that later. Btw if i am not wrong all PS cuts of at a specific speed In MUL cars, its 60kph
Old 3rd August 2005, 12:11   #40
Thanked: 48 Times
Is that so? I am thinking otherwise now. In fact, I thought the same as you and started this thread. If it gets cut off at 60 kmph, the driver is bound to get confused (as my friend puts his experience). It has to be gradual.
RX135 is offline   Reply With Quote
Old 3rd August 2005, 12:32   #41
Technocrat's Avatar
I believe at 60 Kph the steering is smooth enough to notice whether PS is off or on. yeah it must be gradual but that happens only in EPS & not in HPS.
Old 3rd August 2005, 13:22   #42
Thanked: 9,692 Times
Wink
If you can read betwen the lines - driving with EPS is like wearing a rubber suit - some of the fun but a direct loss in sensitivity. Nothing like direct contact
Old 3rd August 2005, 14:22   #43
Technocrat's Avatar
LOL ajmat.
But frankly speaking I have felt otherwise I get more responce from the MY Alto's EPS than for any HPS that I have used(Esteem, Santro)
I'll give an example, I had this habit of eazing the grip on the steering wheel after a turn to resume to staright position(very easy & convenient in no PS cars) I missed this feeling in HPS cars but surprisingly I get this in my Alto's EPS
Anybody else observed this ??
Old 13th May 2006, 14:43   #44
Thanked: 2,025 Times
Infractions: 0/1 (4)
Originally Posted by dceite
hmm.. the EPS of my wagonR is supposed to be speed sensitive.. hard at higher speeds and light at lower speeds.. its so smooth, that its actually called by many as the BEST power steering in any Indian car. Hyraulic power steering i think has constant sensitivity.. so had you been taking that turn at 80 (just kidding..) imagine what would have happened with HPS...
All power steering be it electric or hydraulic are weighted. As the car gets to higher speeds, the effort for turning the wheels gets lesser. Hence its built into the power steering that max force is exerted at stand still. There is no way that a hydraulic steering will react in an odd way at say 80kmph else we wud have heavy vehicles like volvos involved in crashes at every turn on the highways
Ravi
apachelongbow is offline   Reply With Quote
Old 13th May 2006, 14:45   #45
LOL ajmat.
Yes, thats because the alto's power steering cuts off at speeds greater than 20kmph. After that the ps is like manual steering.
Ravi
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
difference between hydraulic and electronic power steering archat68 Modifications & Accessories 1 11th August 2007 19:46
