Old 12th July 2009, 23:16   #16
d3mon's Avatar
Thanked: 622 Times
Originally Posted by .anshuman View Post
Softest of the lot - Punto.
I can second that. Not that the swift's clutch is hard by any stretch of imagination, but the Punto's clutch is like smearing honey into Keira Knightley, to borrow one of JC's expressions.
But I still prefer the swift's clutch. For it's feel. It might be a little bit harder, but sure gives a great feedback when it's engaging. And that makes it a bit easier to pilot in the city.
d3mon is offline   Reply With Quote
Old 13th July 2009, 02:17   #17
Thad E Ginathom's Avatar
Thanked: 8,378 Times
My Swift's clutch is a very gentle thing
Old 17th October 2010, 21:36   #18
Thanked: 64 Times
i have always wondered, why is the clutch play longer in diesel cars compared to petrol for example Linea MJD and T-jet respectively.
Mindgrinder is offline   Reply With Quote
Old 18th October 2010, 12:31   #19
Thanked: 49 Times
Punto is sure soft, by the play is very long. On my vista its hard for sure, but it doesnt travel all the way
vista_qjd is offline   Reply With Quote
Old 18th October 2010, 20:29   #20
Thanked: 64 Times
Note from Team-BHP Support: Please note that Bumping a thread is STRICTLY prohibited on Team-BHP and is considered as Spam. Future instances of bumping up threads will have your account infracted. We request your co-operation in maintaining the quality of our forum.
Thanks,
The Team-BHP Support
Last edited by .anshuman : 18th October 2010 at 21:30. Reason: Please take a look at the Mod end added to your post.
Old 25th October 2010, 12:33   #21
i had both petrol and crdi accent's. the diesel's clutch was way too heavy compared to the petrol ones.
Zero Cool is offline   Reply With Quote
Old 25th October 2010, 12:56   #22
yogeshnaik's Avatar
Thanked: 41 Times
The clutch of Indica Vista Quadrajet is hydraulic. The specified cars have the same FIAT Multijet diesel engine mated to Fiat's gearbox. Hence the clutch is soft. With the mechanical clutches, it will be very hard.
yogeshnaik is offline   Reply With Quote
Old 25th October 2010, 17:01   #23
Thanked: 268 Times
Please correct me if I am wrong. I thought Swift DDiS uses Maruti's gearbox that is mated to the MJD. It is not the case?
pacman2881 is offline   Reply With Quote
Old 31st October 2014, 22:44   #24
adit mishra's Avatar
This may sound odd but you have to try it to believe me. Drive around 10 kms in the morning barefooted. Remove any shoes or slippers. There is always a difference in vibration levels when you drive barefooted. Driving with shoes will surely make the vibrations/harmonics transferred from the engine to your body less. Has anyone tried it out or is it just psychological phenomena? I always change my engine oil after every 7500 kms when more harmonics reach my foot. Is it really a veritable test to decide the car's condition? Driving barefooted.
Hi pacman,
Actually the Swift DDIS uses the maruti's gearbox mated to the DDIS/MJD. But the fiat engine feels the best when mated to a fiat gearbox. The punto is a world class vehicle miles ahead of the swift in terms of build quality. The punto gearbox is very good with longer throws. The ritz diesel has a very comfortable gear lever placement. But the short throws sap all the fun that a spirited driver crazes for. The swift gear box is perfect though not the best. And clutch fluid used by maruti is quite hygroscopic. It is easily contaminated by moisture. After 2 years the feel is not very encouraging. Also when you rev the car to higher rpms the clutch feel is quite rough.
Mod Note : Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the SAME THREAD!
To know how to multi-quote, click here (How to MULTI-QUOTE (when replying to a thread) on Team-BHP).
We advise you to read the Forum Rules before proceeding any further.
Last edited by moralfibre : 2nd November 2014 at 19:10. Reason: Back to back posts
adit mishra is offline   Reply With Quote
Old 6th August 2015, 21:52   #25
blackstallion76's Avatar
Thanked: 12 Times
Default Re: How come Swift DDiS and Indica Vista have such soft clutch?
Went through the thread.
Now, can I put Vista Quadrajet Clutch Kit to Punto MJD. I heard from some technicians that the Quadrajet Clutches are good and last longer. My Punto MJD clutch is already giving some gear shifting issues at 51000kms. Please advice.
Also the cost of quadrajet clutch kit is 3650 and punto mjd clutch kit is 5700 as per 99rpm.
blackstallion76 is offline   Reply With Quote
Old 17th August 2015, 01:12   #26
Thanked: 12 Times
Any suggestions please.
Old 17th August 2015, 01:32   #27
Thanked: 14,610 Times
Check what all are there in the kit for the probe difference you find.
Generally during a clutch change, all 3 critical parts are changed at one go for better reliability.
1) Clutch plate,
2) Pressure plate,
3) Clutch release bearing.
May be the quadrajet kit doesn't contain the clutch release bearings whereas the one on 99rpm contains. Hence the difference.
On an average these should be the costs of the individual parts:
-- Clutch plate: ₹1600
-- Pressure Plate: ₹1097
-- Clutch release bearing: ₹3100
-- Transmission oil : ₹900 for 2.6 ltrs.
Above are prices for clutch kit for Swift DDiS from MGP retail outlet.
a4anurag is online now   Reply With Quote
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
Indica Vista MJD vs Palio MJD vs Swift DDiS greenhorn The Indian Car Scene 452 24th April 2010 18:11
economy diesel duel: Maruti Ritz DDiS vs Suzuki Swift DDis vs Vista quadrajet aura. s_pphilip Test-Drives & Initial Ownership Reports 25 29th October 2009 09:43
