Old 23rd December 2008, 14:22   #16
shreyasma's Avatar
Originally Posted by vishalpipraiya View Post
@shreyas: great stuff. no pic of the roof light? you have posted the final product snaps, none of the process? opening the console etc.?
I will post the roof light snaps.
All other pics turned out very very blurr..So couldnt post it
shreyasma is offline   Reply With Quote
Old 24th December 2008, 09:02   #17
thanks. mainly i wanted to know if the process for esteem was any different than the one mentioned for baleno in this thread:
http://www.team-bhp.com/forum/diy-do...st-rs-4-a.html
appreciate your response.
vishalpipraiya is offline   Reply With Quote
Old 29th December 2008, 13:45   #18
shreyasma's Avatar
The process is the same bro
Old 29th December 2008, 20:41   #19
vivekji05's Avatar
Thanked: 76 Times
Seems like I had inspired a few of you to take up this simple,inexpensive mod.
And you did it for Rs.3/-
It seems that the paper you used is slightly different from the one I used. Mine was more transparent.
Originally Posted by nawabnabeel View Post
i have also done the same trick with backlighting of the ac switches but as it has a green stickering on it which i didnt try to remove, it is not giving that bright red look instead its looking light pink. will try to post pic soon.
The trick here is to use more layers of paper to give the correct red colour. too thick and it goes dark, too less and it will be pink.
Any questions are welcome.
vivekji05 is offline   (1) Thanks Reply With Quote
Old 9th January 2009, 23:23   #20
skyliner34's Avatar
Thanked: 63 Times
Default removing zen instrument cluster
@vivekji05 - any idea as to whats the best way to remove zen's instrument cluster.....
the screws are at the lower top of the instrument :(
skyliner34 is offline   Reply With Quote
Old 10th January 2009, 06:40   #21
vivekji05's Avatar
Thanked: 76 Times
Can you post the pics? Or else I will go and take a look at someone's Zen.
vivekji05 is offline   Reply With Quote
Old 26th May 2012, 23:07   #22
adityasiera's Avatar
Thanked: 245 Times
Default Re: esteem instrument cluster backlighting changed to red
no work today meant, time to do some DIY, we did change the backlights of my friends OHC Vtec and my Esteem..
Few points for others who want to do it.
Esteem - the speedo cable is on the left handside and you have to get a leverage to move the console a bit, find the clip holding the speedocable, press and release.. presto!!
OHC Vtec - The speedo cable is on the right handside, do the same as above.
you also have to change the diffuser strip, that sits right above the cluster.
Get the Blue divider out, and place the gelatin paper strip.
Voila!!
esteem instrument cluster backlighting changed to red-img_20120526_220308.jpg
esteem instrument cluster backlighting changed to red-img_20120526_220325.jpg
esteem instrument cluster backlighting changed to red-img_20120526_220603.jpg
esteem instrument cluster backlighting changed to red-img_20120526_184401.jpg
adityasiera is offline   (1) Thanks Reply With Quote
Used Parts (Instrument cluster- dials) ..? gary_yuen42 Modifications & Accessories 38 9th April 2014 13:31
Project Baleno: RED backlighting for the dials. Total cost= Rs.4 vivekji05 Technical Stuff 78 13th October 2010 00:03
can the colour of the in dash instrument cluster lights be changed??? mclaren1885 Modifications & Accessories 23 22nd August 2009 16:04
Is it possible to change the instrument cluster display? passion4cars Modifications & Accessories 41 15th March 2009 22:54
Instrument cluster light change nikibusa Motorbikes 7 10th September 2005 09:26
