Old 15th December 2008, 18:58   #1
Default Accent ECU Reset - Is it advisable?
Hi, I have an accent which is 58k kms old. Year 2000 model. Converted to lpg 3 years ago. I had a problem with the injectors (two) which I got replaced in June 2008 at Jaya Auto. During the period and after getting it replaced my mileage has dropped to 7 kmpl on LPG . It used to give me 8.5 kmpl before.
What could be the problem? Would it help resetting the ECU?
jasher26 is offline   Reply With Quote
Old 16th December 2008, 11:40   #2
Hi Jasher,
I have an LPG Accent myself,I don't think it would be advisable to remap the ECU.You might end up complicating matters further.I'd reckon that the engine rev setting / tuning might have gotten changed while getting your injectors replaced.Get the engine tuned by your regular mechanic for efficiency and then check.I'm assuming obviously that your driving style hasn't changed in the last few months
maverick030581 is offline   Reply With Quote
Old 16th December 2008, 13:40   #3
Originally Posted by maverick030581 View Post
Hi Jasher,
no driving style has not changed. Infact been very conservative in last 8 - 9 months. change gears at 1800 rpm et al and dont cross 60 - 70 kmph. What kind of mileage is it giving you?
Dad just refilled the lpg and it had done 320 in 46 litres. It used to do 360 in 46 litres earlier
Will get the tuning checked but that does not seem to be the problem as I had got it checked after getting the injectors replaced
Old 16th December 2008, 14:03   #4
It used to give me an average of 9 in city with AC on,nowadays just drive it on petrol though due to some trouble in running on LPG that I haven't gotten around to fixing yet.I had the same problem when I cleaned my injectors earlier but after getting it retuned by my regular mechanic and lowering the revs on idle,it was back to the usual average.
If tuning doesn't help then you might need to remap the ECU(assuming the exhaust system is functioning smoothly,a problem there could also lead to low average).Haven't done it myself yet so I wouldn't be the best person to advise you on this.But if the common factors for low average are ruled out in your case I suggest you take it to your LPG guy and have him check it.
Old 16th December 2008, 17:22   #5
kapilsharma80's Avatar
Thanked: 25 Times
jasher, you can consider resetting your ecu. mileage would be low for couple of tank / cylinderfulls.
kapilsharma80 is offline   Reply With Quote
Old 16th December 2008, 18:30   #6
yogi1771's Avatar
Isn't resetting and remapping the ECU two different things ??
yogi1771 is offline   Reply With Quote
Old 16th December 2008, 18:49   #7
vikram_d's Avatar
Thanked: 936 Times
Yes they are two different things. Maverick has them confused with each other. Resetting ECU is a simple thing. Just disconnect battery negative wire and leave for 15 - 20 mins. When you reconnect the ECU would have reset to factory defaults.
Old 17th December 2008, 09:48   #8
Right you are mate,I had them mixed up.Since I'm a greenhorn I didn't know much about ECU Having read a couple of threads on the same I'm a li'l more enlightened now.Understood the resetting part but could you help me out with the remap bit?Is it done by tuners for performance increase??
Old 17th December 2008, 10:35   #9
another thing I observed, the car on the first start of the day, on petrol always, the rpm goes up to 1100 - 1300, is this normal? as I cant remember how it was earlier
Old 17th December 2008, 11:03   #10
vikram_d's Avatar
Thanked: 936 Times
This may be OT here. Search for ECU remap. You will get a lot of info on the forum.
Old 17th December 2008, 11:35   #11
ask77's Avatar
It is normal if it is a cold start but if the idling RPM goes up on hot starts also and especially on LPG then the problem can be leakage in inlet manifold also get the car retuned by your lpg refitter for the average problem. Do you have Lambda installed in your LPG kit ? Is the engine check light ( Yellow ) lit on LPG ?
ask77 is offline   Reply With Quote
Old 17th December 2008, 12:37   #12
Tejas@perioimpl's Avatar
Thanked: 4,877 Times
Jaideep, just try the reset... if at all, it won't work, but will definitely not harm your car.
And as i have been telling you since the past few months, sell your car and buy mine!
Tejas@perioimpl is offline   Reply With Quote
Old 17th December 2008, 12:56   #13
wish if it was as easy as that
idling rpm does not go up on warm starts, infact that used to happen when my injectors conked off.
the yellow light is not lit on LPG
Note from the Team-BHP Support Staff : Please use "Multi Quote" option for quoting Multiple posts.
Old 4th May 2009, 02:40   #14
Danindica's Avatar
Default Indica ECU
Guys, I have an Indica XETA(PETROL) that I ran really conservatively in the first 3-400 kilometers. Just wanted to know if the ECU could be reset without too many complications? While the car is powerful and has a good pickup etc, some more BHP would do no harm eh!
Danindica is offline   Reply With Quote
Old 4th May 2009, 09:58   #15
sgiitk's Avatar
Thanked: 3,752 Times
Getting more power demands a change in the map. There are after market products for the purpose. However, remember your warranty goes for a toss if you do so.
Odometer Reset on Apache FI FZ6 Motorbikes 18 28th August 2012 18:01
Reset ECU after installing K&N PatienceWins Technical Stuff 20 6th July 2010 16:15
Esteem Battery discharged -ECU reset muke31 Technical Stuff 12 4th September 2008 16:03
