Old 18th March 2011, 09:19   #16
wildon's Avatar
Thanked: 1,061 Times
Default Re: Warranty declined for Front brake Disc worn out in 37 K Kms
Have you been braking in corners?
Does the car pull under braking?
Originally Posted by pjbiju View Post
Get the calipers checked. If the caliper pistons of the RH side brake are stuck while it is partially out, it will put pressure on the pads leading to wear. If that is the case, your vehicle also should pull to a side on a level stretch since one of the brakes is partially engaged. I cannot think of any other reason for this, since the brake forces are distributed evenly between the front brakes, unless it has ABS. Also what is your car make? Does it have ABS?
My car does pull to left, while driving also while in braking, it has gone 2-3 time to correct that. Its a Hyundai i20 with ABS.
How much more worn is the RH as compared to the LH? If its minor, there's no major cause for concern....
Same applies for tyre wear. Hence the importance of regular tyre rotation.
If the difference is MAJOR -- check your braking system as your LHS pistons might be jammed etc.
As per the technician LH side pad are good and it doesn't need any replacement. But RH need to be changed as it wont last till next service.
Originally Posted by SirAlec View Post
Just to check, are you using oversize alloys/tyres?
No. its all stock.
wildon is offline   Reply With Quote
Old 18th March 2011, 10:55   #17
vikram_d's Avatar
Thanked: 940 Times
Seems like a brake balance issue to me. May be the ABS controller is pumping out more pressure to the RH side brake. Get the ABS unit and all it's allied accessories checked. My dad's ABS swift also had a similar problem and we found a dent in the hydraulic line going to the front LH wheel. Because of the dent the RH side was getting more braking force than the LH side and consequently the RH side would wear out quicker. So get the all the brake lines also checked.
Old 18th March 2011, 11:37   #18
wildon's Avatar
But under normal braking condition ABS will not come to play is it? or i'm wrong?
if ABS not comes into play in normal condition how will be the brake distribution?
Old 18th March 2011, 12:26   #19
Thanked: 175 Times
I guess we are taking about ABS and EBD here. EBD will ensure brake force distribution depending on many factors like load, road grip, car angle etc under normal driving. ABS will come into picture only when wheels are about to lock. So it might be the EBD which is not doing the job properly (chances should be less though). Just my views.
amit1234singla is offline   Reply With Quote
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Does ABS result in much faster Worn-Out Disc pads ? kri$hna Technical Stuff 47 9th September 2011 16:22
Can a front disc brake be fitted on Bullet 350 standard model from enfield OEM parts? sidindica Motorbikes 27 26th August 2010 15:53
Rear Pads Worn Out Faster Than Front Pads! How is this possible? Tripod Technical Stuff 13 29th April 2009 22:16
Suzuki Declined Joining Fiat-tata India Engine Production Joint Venture sushanthr77 The Indian Car Scene 3 1st August 2008 18:51
