Old 18th December 2008, 12:09   #1
gadadhar's Avatar
Thanked: 233 Times
Default Warranty declined for Front brake Disc worn out in 37 K Kms
I own a Hyundai Elantra CRDI that has done 37,000 Kms. It is in to it 3rd year and is on the extended manufacturer warranty
During 10 K routine service in Trident Hyundai I was informed that from brake drums (both) have worn out and this won't be covered under extended warranty since it is wear and tear item.
I logged a complaint with Hyundai Customer care but got the same response
I would like to know your expert advise on whether brake drum is a part that can get damaged in 37,000 Kms under normal driving conditions with all routine maintenance done at specified service interval in Hyundai Authorized servicing centre (Trident Hyundai)
Thanks in advance.
Bobby
gadadhar is offline   Reply With Quote
Old 18th December 2008, 16:07   #2
kapilsharma80's Avatar
Thanked: 28 Times
Bobby, it is true that brakes are not covered under warranty.
for brake repacement intervals, why don't you check with other elantra users.
i have seen / heard honda users change their brakes after 25 - 28 k kms.
kapilsharma80 is offline   Reply With Quote
Old 18th December 2008, 19:59   #3
doesnt the elantra come with all four wheel disc brakes
harry2223 is offline   Reply With Quote
Old 18th December 2008, 20:22   #4
nitrous's Avatar
Thanked: 285 Times
Have you worn out just the brake shoes or the hubs along with it?
Old 22nd December 2008, 09:56   #5
gadadhar's Avatar
Thanked: 233 Times
Small correction.. Its the front Brake Discs that has got worn out (not the drum since it is all disc brakes.. and to confirm, it is not just the pads )..
Old 22nd December 2008, 10:45   #6
DieselFan's Avatar
Thanked: 234 Times
When did you have your car last serviced. Ask the HyundaiASS why the brake pads were not replaced in the earlier service or why that was not checked and brought to your notice before this incident happened.
DieselFan is offline   Reply With Quote
Old 22nd December 2008, 13:12   #7
Rehaan's Avatar
Thanked: 25,037 Times
gadadhar,
Unless im missing something here - i dont see why the warranty should cover your brake pads at 37,000kms - given that they are wear and tear items and usually come to the end of their life around this mileage.
If you could be a little clearer as to exactly what part (pads? discs? etc?) has worn out -- that will help you get some better and more specific advice here.
cya
R
Old 22nd December 2008, 15:00   #8
Thanked: 660 Times
Disc are also not covered under warranty. As it depends upon how timely you change your pads. IF you overuse your pads, the disc will eventually worn out.
If there are any manufacturing defects like cracks, etc . then it will be covered under warranty.
Old 22nd December 2008, 17:55   #9
gadadhar's Avatar
Thanked: 233 Times
Thanks for all your comments
Since there are few posts asking for clarifcation, let me try to add some points
1. Worn out part is the front Brake Disc (both sides)
2. All specifed routine services were done at Trident Hyundai at proper intrevals
3. During last service at 30 K service back break pads (not disc) was replaced, but back were not done
4. Now during service at 37 K, I was informed that front Break drums are damaged. It was informed that this may have happened since the break pads have worn out (then why it was not replaced during last service)
Hope above helps
Old 22nd December 2008, 18:04   #10
vikram_d's Avatar
Thanked: 940 Times
I would suggest you to check the brake discs yourself. All brake discs come with a minimum thickness marking on them. Measure the thickness of the discs to confirm that the guys are telling you the truth. If the thickness of the discs is less than the marked thickness then change them. If it is more no need for changing them.
The marking will be something like 18mm, 15mm etc. That is the minimum permissible thickness for the brake discs.
Old 17th March 2011, 09:48   #11
wildon's Avatar
Thanked: 1,061 Times
Default Re: Warranty declined for Front brake Disc worn out in 37 K Kms
My Front RH side Discs brake pad is reported to be nearing its life cycle and LH side side still doing good as per the technician. is anything unusual here? as one is worn out faster. The car is nearing 20k in 1.6 years.
wildon is offline   Reply With Quote
Old 17th March 2011, 10:35   #12
Thanked: 10,991 Times
Have you been braking in corners?
Apart from that remember, there is more weight on the drivers side all the time due to steering gear and the driver so the right side has more weight distribution to cope with.
Another point are the road surfaces create differences.
Does the car pull under braking?
Did some matter get in between the pad and disc and create excessive wear
one needs to understand the differences in the wear and see the components before concluding on this
Old 17th March 2011, 10:41   #13
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
Get the calipers checked. If the caliper pistons of the RH side brake are stuck while it is partially out, it will put pressure on the pads leading to wear. If that is the case, your vehicle also should pull to a side on a level stretch since one of the brakes is partially engaged. I cannot think of any other reason for this, since the brake forces are distributed evenly between the front brakes, unless it has ABS. Also what is your car make? Does it have ABS?
pjbiju is offline   Reply With Quote
Old 17th March 2011, 11:43   #14
Rehaan's Avatar
How much more worn is the RH as compared to the LH? If its minor, there's no major cause for concern.
One reason is that left handers are usually taken faster in city driving (in RHD countries), since they are usually free lefts.
When taking a free left turn : The RHS (outside) front wheel will be turning faster than the LHS (inside) front wheel, and its usually accompanied by some "trail braking" as you go into the corner, wearing out the RHS (outside) brake pad faster. There will also be more weight on the outside wheels due to centrifugal force.
This doesn't happen anywhere as often for right turns, since usually you have to wait at a traffic signal before taking that right turn, and therefore speeds are slower, less weight transfer, and there is no trail braking.
Same applies for tyre wear. Hence the importance of regular tyre rotation.
If the difference is MAJOR -- check your braking system as your LHS pistons might be jammed etc.
cya
R
Old 18th March 2011, 00:45   #15
Thanked: 660 Times
Just to check, are you using oversize alloys/tyres?
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Does ABS result in much faster Worn-Out Disc pads ? kri$hna Technical Stuff 47 9th September 2011 16:22
Can a front disc brake be fitted on Bullet 350 standard model from enfield OEM parts? sidindica Motorbikes 27 26th August 2010 15:53
Rear Pads Worn Out Faster Than Front Pads! How is this possible? Tripod Technical Stuff 13 29th April 2009 22:16
Suzuki Declined Joining Fiat-tata India Engine Production Joint Venture sushanthr77 The Indian Car Scene 3 1st August 2008 18:51
