Old 24th August 2009, 15:50   #31
Thanked: 21 Times
Default Indica Vista OBD
Originally Posted by sun View Post
As I said before, I had seen the TATA service personnel in action on my Safari 2.2 l. On the hardware connector was written ISO 14230. That should be the protocol.. right ?
Hope this was useful.
Since my scan tool [ELM 323] is compliant withISO14230, the PCM Scan should have recognized it.....Am i missing out on any settings....Will post the screen shot of the error shortly...
Note from the Team-BHP Support Team : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Last edited by Technocrat : 24th August 2009 at 17:31. Reason: Please read the note in post, thanks
svdath is offline   Reply With Quote
Old 24th August 2009, 15:54   #32
Thanked: 245 Times
Originally Posted by svdath View Post
Dadu,
Tried using the PCMScan trial version..>It was able to recognize hte ELM323 scanner..But it then gave a error message that the protocol was not recognized. Is TATA using its own propritery protocol. I thougt it was a ISO-9141-2. Also, when i connet the ELM323 to the OBD connector, i get one red led light on the scan tool, but there is one more which does not glow, is that a problem? I bought mine from Car PC Systems | Vehicle Infotainment Solutions | iRide Technologies, Mumbai, India
Also, is there a way to find out what is the protocol by some AT command? I keep getting the BUS INIT.....ERROR message
It uses ISO 14230-4 (KWP2000 FAST) protocol.
Connect using Hyperterminal with the following :
Set Bits per second to 9600
Data Bits to 8
Parity to None
Stop bits to 1
Flow Control to None
Type 'ATZ' and hit enter, what do you get ??
Type '010C' and hit enter, what do you see ??
Old 24th August 2009, 20:06   #33
Thanked: 21 Times
Data Bits to 8
Parity to None
Stop bits to 1
Dadu,
Still no luck I have attached the screenshot.Is there any other setting that i need to make?
Old 25th August 2009, 09:15   #34
sun
sun's Avatar
Thanked: 7 Times
your indica vista is Quadrajet or with TATA engine ? If its Quadrajet, then may be it has some FIAT protocol ?
sun is offline   Reply With Quote
Old 25th August 2009, 10:30   #35
Thanked: 21 Times
Its the Quadrajet running the Fiat 1.3 MJT. I googled and saw that Fiat also followed the ISO protocols. Now i am in a confused state whether there is problem with my OBD connector
Old 25th August 2009, 16:45   #36
Thanked: 245 Times
Yours is an older version of ELM-323, current is 327, do the following on the hyperterminal,
- Turn on the Ignition and Set the protocol to Auto by typing ATSP0 (last digit is zero) and then issue a 0100. if it doesn't respond its a non-standard OBD ECU.
- When it responds check the protocol by typing in ATDPN.
- Whatever number is returned now type in ATSP N (where N is the number the previous ATDP command returned)
- Now type in ATMA and post the results.
Old 25th August 2009, 17:46   #37
Thanked: 245 Times
ELM323 supports: ISO14230-4 (KWP2000) ISO9141-2
ELM327 supports: ISO15765-4 (CAN) ISO14230-4 (KWP2000) ISO9141-2 J1850 VPW J1850 PWM
So if the vehicle ECU needs other than the ELM323 protocols, it will not work.
Old 25th August 2009, 19:01   #38
Thanked: 21 Times
Dadu,
It looks like i will need to go for the ELM327. I have attached the screen shot of the auto protocol setting. This itself did not go through. But do you think that me going for the ELM327 would solve the problem. Is there a one where I can test and then go for buying it?
Old 25th August 2009, 22:26   #39
Thanked: 84 Times
I've had my go at Palio MJD with my ELM327 and it simply doesn't work. Always say "Unrecognized Protocol" or something similar.
Later learned from FIAT forums that FIAT uses some proprietary protocol which requires special SW.
Good luck to you! It would be a pleasant surprise if it ever works on Vista MJD.
Digital Vampire is offline   Reply With Quote
Old 26th August 2009, 14:14   #40
Thanked: 245 Times
Dadu,
Like I said earlier, it seems like a non-compliant OBDII ECU, usually Fiat should use ISO only. You can test with someone having ELM327 before opting to buy.
Old 26th August 2009, 20:08   #41
DRC
DRC's Avatar
Thanked: 48 Times
Fiat (old) uses the ISO 14230-4 KWP fast init for communication with ECU. But the langguage it speaks is very different from OBD-II or EOBD. I have had some success in communicating with my Petra ECU through hyper terminal. I could not make a program as I do not understand software code so much.
However, I thought new MJD engines complied to EOBD standards! I am surprised it doesn't!!!
DRC is offline   Reply With Quote
Old 26th August 2009, 21:25   #42
Thanked: 21 Times
Can you let me know what were the commands you used with Hyper terminal and also what was the connector you used - ELM 323 or ELM 327?
Old 26th August 2009, 22:01   #43
sun
sun's Avatar
Thanked: 7 Times
svdath, I inquired with TATA personnel today, Fiat indeed uses different protocol. They have different hardware to connect to quadrajets and 1.3 Fiats. Even the software is different, though he did not mention which .
Old 27th August 2009, 11:10   #44
DRC
DRC's Avatar
Thanked: 48 Times
I used a ELM327.
The sequence of the commands were too long and clumsy (atleast for my laziness). Please PM your mail ID, I will send some scatch pad which I made while trying to decode. If you can write some code in c# and live in bangalore, we can put together a program to do this job.
Old 27th August 2009, 13:43   #45
sun
sun's Avatar
Thanked: 7 Times
Check this -
Wow..I just Connected my Palio to Laptop via OBD II cable today~! - The FIAT Forum
(Link taken from another thread)
"Check Engine" light also indicates ECU "relearning" ? anandpadhye Technical Stuff 28 19th August 2017 09:54
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Tata Safari Dicor 2.2 Paint Code Sankar Modifications & Accessories 10 6th April 2008 00:33
