Old 27th August 2009, 15:34   #46
DRC
DRC's Avatar
Thanked: 48 Times
So I am still hoping that my assumption (new Fiats are EOBD) is true.
Wonder why MJD dont talk OBD?
DRC is offline   Reply With Quote
Old 27th August 2009, 16:06   #47
DRC
DRC's Avatar
Thanked: 48 Times
Oops! I think I spoke too early...
This is not an Indian Palio. The guy claims he is a chinese, (does Fiat sell in China?).
Neither the model and version of the car clear.
Old 29th August 2009, 17:29   #48
Thanked: 21 Times
Default Indica Vista OBD
here we go with a new error. I got a ELM327 and this is the error I am getting when I am connecting through Digimoto Lite. Any further suggesstions
svdath is offline   Reply With Quote
Old 29th August 2009, 20:37   #49
Thanked: 245 Times
Well nothing much, the ATS0 command tell the ELM to go into Auto protocol mode and will very much try with each protocol it can, but as from your SS it wasnt able to connect.
Old 4th September 2009, 19:43   #50
sun
sun's Avatar
Thanked: 7 Times
Well I managed to get mine working .. my 2.2 @ idle
sun is offline   Reply With Quote
Old 5th September 2009, 22:16   #51
Thanked: 21 Times
Which is the software that you are using?
Old 6th September 2009, 12:57   #52
Thanked: 245 Times
Its a centrafuse skin..
Old 25th October 2009, 10:52   #53
Thanked: 21 Times
Bringing this thread back to life. I was at Prerana motors ,OMR for the AC update. There I saw this guy connecting the OBD connector. Though he did not know much, he was able to give me the information that it was CAN and k-line connector. I saw on the OBD connector also, that the CAN and k-line LEDs were on when the communication was happening. I forgot the name of the connector though.
Now to my fav part, asking questions
I know that ELM 327 connector supports CAN but not sure if it supports the K-line.
Dadu: Your inputs required.
Old 25th October 2009, 17:41   #54
Thanked: 245 Times
I do not know what K-line is, if its a prop. hardware then so be it because K-line is definitely not a standard OBD protocol.
Old 29th October 2009, 12:33   #55
headers's Avatar
Thanked: 464 Times
@ dadu: Wonderful thread
Can you give me some pointers as to how to get the hardware and is it universal plug and play for all diesel / petrol vehicles or otherwise?
Maybe should get cracking on the codes for all vehicles !!
cheers
Old 29th October 2009, 12:39   #56
Thanked: 245 Times
cheers
Hardware can be ordered online, either delivered directly in India (risk with customs) or to someone in US and then carried personally to india.
Its universal as long as the Manufacturer has followed the OBDII standards. Supports all OBDII protocols. If the vehicle supports OBD, the OBD codes are pretty well defined, so no need to put efforts there.
Old 29th October 2009, 13:13   #57
tsk1979's Avatar
Thanked: 16,012 Times
Can someone tell me which hardware or software I should buy from the US?
Old 29th October 2009, 13:44   #58
DRC
DRC's Avatar
Thanked: 48 Times
K line and CAN are 2 different protocols. ELM 327 support both of them.
You can get the ELM 327 datasheet online. It might help.
Old 29th October 2009, 13:51   #59
Thanked: 245 Times
hardware as mentioned earlier in the thread along with recommended software but many choices for software are available.
Just checkde, K line = KWP protocol.
Old 29th October 2009, 15:28   #60
DADU .. I am a slow on Tech. Can you therefore confirm whether this will serve the purpose for reading the ECU codes ?
kingshukt is offline   Reply With Quote
"Check Engine" light also indicates ECU "relearning" ? anandpadhye Technical Stuff 28 19th August 2017 09:54
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Tata Safari Dicor 2.2 Paint Code Sankar Modifications & Accessories 10 6th April 2008 00:33
