Old 29th October 2009, 16:24   #61
Thanked: 245 Times
yes but only the basics, read error code and erase them, the ELM ones with software can do much more like designing you own dashboards, saving the run data for later analysis etc. For apprx $20 more (hardware cost).
Old 29th October 2009, 16:30   #62
tsk1979's Avatar
Thanked: 16,012 Times
Dadu, what about this?
DealExtreme: $29.99 ELM327 USB Vehicle OBD-2 Scanner Tool
Its ELM 327
then there is this one
DealExtreme: $24.70 VAG-TACHO USB Vehicle OBD Cable with Software CD
Old 29th October 2009, 16:47   #63
Thanked: 245 Times
ELM one will work with all OBDII complaint vehicles but am not sure on the VAG one, as they will work only with certain vehicles like VW, BMW and Skoda.
The ELM one is a real good deal, I think I bought one for some $87, worth buying.
Old 29th October 2009, 17:33   #64
DRC
DRC's Avatar
Thanked: 48 Times
@svdath, I justt sent you a mail with ELM327 datasheet.
As I understand, K-line is a physical layer spec (one wire). KWP 2000 is a layer above it not sure about the specs though. K-line spec is similar to UART in simplex mode (can not quote a source, but remember having read it somewhere)
DRC is offline   Reply With Quote
Old 5th February 2010, 13:07   #65
Thanked: 33 Times
OBD on Scorpio
Hi guys, following the tips in the thread I tested out the ELM327 on my 2006 Scorpio. Here are the results from the communication (using PROSCAN):
ELM > 0100
4100983B0011
ELM327v1.5a > ATDPN
A3
ELM327v1.5a > ATSP 3
OK
ELM327v1.5a > ATMA
ERROR: No Response!
ELM327v1.5a >
And here is the full log:
02-05-2010 12:44:47.125 Opening Port 2 (9600 baud) with ELM Timeout = 500 ms.
02-05-2010 12:44:47.203 Comm Port 2 successfully opened.
02-05-2010 12:44:47.218 Tx: ATZ
02-05-2010 12:44:48.140 Rx: ELM327v1.5a[ELM327v1.5a] (ATZ)
02-05-2010 12:44:48.140 Tx: ATE0
02-05-2010 12:44:48.187 Rx: ATE0OK[ATE0OK] (ATE0)
02-05-2010 12:44:48.187 Tx: ATL0
02-05-2010 12:44:48.250 Rx: OK[OK] (ATL0)
02-05-2010 12:44:48.250 Tx: ATI
02-05-2010 12:44:48.312 Rx: ELM327v1.5a[ELM327v1.5a] (ATI)
02-05-2010 12:44:48.328 Tx: ATST7D
02-05-2010 12:44:48.375 Rx: OK[OK] (ATST7D)
02-05-2010 12:44:48.390 Tx: ATBI
02-05-2010 12:44:48.437 Rx: OK[OK] (ATBI)
02-05-2010 12:44:48.437 Tx: ATSP0
02-05-2010 12:44:48.515 Rx: OK[OK] (ATSP0)
02-05-2010 12:44:48.515 Tx: 0100
02-05-2010 12:44:53.359 Rx: SEARCHING...7F0111[SEARCHING...7F0111] (0100)
So After ATMA, I have no response. Should I try changing the default timeout of 500 msec to a larger value?
Thanks a ton. I am sure you guys will help me get more info out of this non-standard protocol.
gharika is offline   Reply With Quote
Old 8th February 2010, 14:12   #66
Thanked: 245 Times
@Gharika, Sorry I overlooked your post till you PM'ed me. Your situation is pretty much the similar to non-compliant OBD. Can you do as suggested in post #36 and revert with the results.
Old 23rd February 2010, 15:15   #67
Thanked: 33 Times
@dadu
Here is what I get from the Scorpio:
ELM > 0100
4100983B0011
ELM327v1.5a > ATDPN
A3
OK
ELM327v1.5a > ATMA
ERROR: No Response!
Old 27th July 2011, 20:54   #68
white-rabbit's Avatar
Thanked: 35 Times
Default Re: Cracking the Da Vinci "TATA Safari 2.2l" ECU Code
planning to get a obd for Beat.I dont know where to start.A little help please
white-rabbit is offline   Reply With Quote
Old 5th January 2012, 15:22   #69
abbey4u's Avatar
Thanked: 108 Times
I got this elm 327 bluetooth device recently and hooked up on my safari 2.2. Used the android software Torque and voila i can see ecu readings.
ELM327 v 1.4 OBDII / OBD2 Bluetooth Diagnostic Interface OBD Scan Car Accessory | eBay
One error code i can see is powertrain P 1650: I am not sure what this code means? Can someone throw some light on what can be the issue
abbey4u is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 15:44   #70
KALINGA's Avatar
Thanked: 280 Times
Googled this code and found this may be a
PSP (Power Steering Pressure) switch out of self test range
Check the below link :-
18058/P1650/005712 - Ross-Tech Wiki
18058 P1650 - 35-10 Powertrain Data Bus?
P1650 Code: Powertrain Data Bus: Missing Message after having a new MFD installed? - AudiWorld Forums
S40 Diagnostic Trouble Code "P1650"
Ford P Powertrain Diagnostic Fault Codes
One basic question.
Is this error code same for all car or its different from company to company ?
KALINGA is offline   Reply With Quote
Old 5th January 2012, 16:11   #71
Thanked: 245 Times
One basic question.
OBD is a standard, as long as the ECU is OBD compliant, the error codes will be standard too.
dadu is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 16:12   #72
abbey4u's Avatar
Thanked: 108 Times
so if its related to power steering, what could be the exact issue and how to fix?
abbey4u is offline   Reply With Quote
Old 5th January 2012, 17:18   #73
Thanked: 98 Times
How can we know about turbo charger from this/ these software(s)? I mean how to know the exhaust gas pressure and condition of turbo (kicked/ sleep) according to it?
(Alok) is offline   Reply With Quote
Old 5th January 2012, 17:28   #74
Thanked: 245 Times
I dont think its an issue, its just telling that the pressure is out of the defined range(could be TATA custom).
You can configure the probe for that sensor, depends on the ECU and software used, they should talk to each other.
Old 30th March 2013, 19:16   #75
jkdas's Avatar
Thanked: 1,435 Times
Tried Fun2drive and it worked ok.
Have posted screenshots here
http://www.team-bhp.com/forum/techni...app-bosch.html (fun2drive - Free Performance & Diagnostic App from Bosch)
Also tried Torque which didn't work sadly and hence tried OBD Car Doctor.
Link https://play.google.com/store/apps/d...ardoctor&hl=en
Might get pro later since free version is working and after I learn to understand the parameters.
Some screenshots...
When you switch on AC...
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185231.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185131.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185140.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185218.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185253.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185306.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185313.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185338.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185416.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185444.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185449.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185513.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185556.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185619.png
Cracking the Da Vinci "TATA Safari 2.2l" ECU Code-screenshot_20130330185659.png
"Check Engine" light also indicates ECU "relearning" ? anandpadhye Technical Stuff 28 19th August 2017 09:54
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Tata Safari Dicor 2.2 Paint Code Sankar Modifications & Accessories 10 6th April 2008 00:33
