Old 28th September 2013, 17:25   #76
saurabh2711's Avatar
Thanked: 273 Times
Default Re: Cracking the Da Vinci "TATA Safari 2.2l" ECU Code
Tried Fun2drive and it worked ok.
Have posted screenshots here
http://www.team-bhp.com/forum/techni...app-bosch.html (fun2drive - Free Performance & Diagnostic App from Bosch)
Also tried Torque which didn't work sadly and hence tried OBD Car Doctor.
Link https://play.google.com/store/apps/d...ardoctor&hl=en
Might get pro later since free version is working and after I learn to understand the parameters.
Some screenshots...
When you switch on AC...
Hi JKDas,
Apologies, I am new to the OBD/ECU world & need to learn this .
Can you please let me know how to connect OBD Scanner to a tata safari.
Where is the port to connect it? I understand that you have some runtime stats for the car, it means there has to be a separate port. Please let me know where it is?
Saurabh.
saurabh2711 is offline   Reply With Quote
Old 28th September 2013, 20:58   #77
Thanked: 245 Times
Originally Posted by saurabh2711 View Post
Hi JKDas,
Saurabh.
Look below the Glove box.
dadu is offline   (1) Thanks Reply With Quote
Old 6th November 2013, 08:02   #78
Thanked: 11 Times
Do anybody know what version of ECU is installed on Tata Safari Strome. Is it same as Tata Safari Dicor. Have anybody used Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII. Would this work for Tata Safari Storme.
csd42419 is offline   (1) Thanks Reply With Quote
Old 23rd June 2014, 16:51   #79
Thanked: 18 Times
I tried this for My Safari Dicor, This is not working
mandyrana is offline   Reply With Quote
Old 25th June 2014, 10:47   #80
Ray32825's Avatar
Thanked: 56 Times
If anybody needs any diagnostic software and hardware from the US let me know, I'm willing to help. Below is a link to a photo album of one of my Panasonic Toughbook laptops.
http://s927.photobucket.com/user/Ray...ghbook%20CF-28
Ray32825 is offline   Reply With Quote
Old 1st August 2014, 14:29   #81
Thanked: 18 Times
Pls suggest good bluetooth OBD scanner for Tata Safari Dicor 2.2
Old 21st December 2014, 10:10   #82
jkdas's Avatar
Thanked: 1,435 Times
I use VGate. Getting paid version Torque Pro as I type.
jkdas is offline   (1) Thanks Reply With Quote
Old 19th May 2015, 19:46   #83
Thanked: 7 Times
hello Das, would please let us know your feed back?
i am researching on the OBD II readers too, found one such here at ebay india
http://www.amazon.in/Vgate-Bluetooth...dp/B00U14YARE/
I will be using with the indica dicor though
krichared is offline   Reply With Quote
Old 19th May 2015, 21:43   #84
devrajman's Avatar
Thanked: 116 Times
For TATA Safari I would suggest OBD CAR DOCTOR app, I have seen app very much compatible with TATA where Torque doenst connect.
Also try FUN2DRIVE
devrajman is offline   Reply With Quote
Old 1st June 2015, 14:06   #85
Turbo_Torq's Avatar
Thanked: 67 Times
I connected using Torque(Lite) and it connected like a breeze and although it didn't show much information which could have helped, it did put out logged DTCs. Any suggestions how could have the software/app put out more info?
Turbo_Torq is offline   Reply With Quote
Old 1st June 2015, 14:19   #86
tsk1979's Avatar
Thanked: 15,837 Times
Unfortunately, in the 2.2(DICOR) you cannot get much info, however, for storme you can get everything including MAF sensor, intake temperature, boost etc.,
On the older 2.2 dicor I could just get the coolant temperature and load.
Old 1st June 2015, 15:17   #87
Turbo_Torq's Avatar
Thanked: 67 Times
Attachment 1377286
Exactly. When I hooked it up, I didn't have the All Data widget set up on the display and I was just looking for DTCs. However, I did note the changes in acceleration and load parameters. I think I'll have to invest in a more professional setup. What hardware/software are you currently using?
Old 1st June 2015, 18:18   #88
asejwal's Avatar
Thanked: 9 Times
I don't know if this is the right thread I should be posting but since it's related to the ECU, I am putting it here...
I have a 2009 2.2Vtt Ex Safari. Recently the 4H and 4L lights started glowing continuously in the dashboard. It began as - they would light up intermittently and then go off. Now this became continuous. And 4x4 was not engaging. I took my SUV to the authorised service station.
At the moment, they have solved the light problem and both 4H and 4L are now engaging. Most probably, they have reset the ECU. They say that if this problem crops up again, ECU needs to be changed which has an MRP of Rs 31000.
I need to ask people 2 things:
1. Is the Safari Main Vehicle ECU and 4x4 ECU the same? because someone told me that 4x4 ECU costs about 1600 only?
2. Secondly, I read in one of the threads on Gearhead that second hand ECUs are available for the Safari. Can you please tell me from where I can get the ECU repaired or buy one second hand?
Anxiously await your replies...
asejwal is offline   Reply With Quote
Old 2nd June 2015, 00:07   #89
Turbo_Torq's Avatar
Thanked: 67 Times
In regards to your first query, I reckon that the ECU for the 2WD and 4WD versions would be the same since 99rpm lists a single one. However, I'd suggest for others to comment on the subject too.
As for the latter part, I'd recommend you to go for a genuine and new ECU since a used one may be busted/malfunctioning which will cause more harm than do any good to the engine and relevant components. Also, the ECU does cost around 27.5k
Hope this helps.
Old 2nd June 2015, 01:21   #90
tsk1979's Avatar
4x4 has a separate extra transfer case ecu under driver seat. Since 4x4s are rare it will be difficult to get one used.
That said when 4x4 lights came on what was the error code. I will put up diagnostic code for 4x4 ecu and how to check on diagnostic manual thread tomorrow
"Check Engine" light also indicates ECU "relearning" ? anandpadhye Technical Stuff 28 19th August 2017 09:54
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Tata Safari Dicor 2.2 Paint Code Sankar Modifications & Accessories 10 6th April 2008 00:33
