Old 26th December 2008, 09:26   #16
KSM-Vtec's Avatar
Thanked: 440 Times
Originally Posted by GTO - Touring View Post
KSM, where are you getting the suspension work done?
@ GTO - I still havent finalised the garage, any suggestions? Was thinking of doing it along with Jitu at the place where he gets his work done in Kandivaly...only because he said that the guy is good and also Jitu is going to be around when the work is being done....
KSM-Vtec is offline   Reply With Quote
Old 26th December 2008, 09:50   #17
Hi KSM
Since you are in Bandra you could also go to Paul Auto garage which is at Pali naka, the owner of the garage Denzel is a good friend of mine & is excellent with his work too. If at all you wanna have a word with him buzz me ill send you his cell no
rgds
cancerm is offline   Reply With Quote
Old 26th December 2008, 10:13   #18
KSM-Vtec's Avatar
Thanked: 440 Times
We can do that for sure..when do we go? I got the quote from a Citi motors at opera house and also other places around. The guy you suggested wanted me to either come down or send a fax, dint find time. Was the quote from Linkway for the entire front setup only?
Originally Posted by Tejas@perioimpl View Post
+1 to that. KSM let me know also, even i feel like replacing my OHC's suspension. Maybe we can buy parts together and get a better discount.
Where did you get your quote from?
Linkway Honda had quoted me 16k for the same thing just for your info.
Old 26th December 2008, 10:43   #19
KSM-Vtec's Avatar
Thanked: 440 Times
The rear shocks are costing me the same as the front(total cost of rear parts 6.5k approx). I intend to get the front setup changed in this round and see if its ok, i guess will take a discision aboout the rear later. Will surly get the steering checked. Thanx a lot.
Originally Posted by ankitahuja View Post
KSM - The quote you got sound pretty fine to me. It's a fair price for parts and labour. I believe that's all you need to change the front suspension.
Two suggestions:
1. Get your rear suspension checked. You can change just the shocks since they are relatively much cheaper than the front.
2. Get your steering serviced as well. The sounds from the suspension could be related. And not to forget that you're running 16"
@ Narayan - Bro, it's better to all of it changed together for an 8 year old car since you don't want to change parts one by one. (She will ask for it sooner or later you know!!).
Old 26th December 2008, 11:42   #20
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Yep, linkway quote was for the front setup only a few years ago.
I'm really busy for the next ten days, so if you're in a hurry, you can go ahead. I have a good mechanic at malabar hill, i'll get a quote from him just to cross check costs anyways and keep you posted.
Getting the steering checked is a good idea; i had to get mine done up some time ago. Vibrations and play was greatly reduced after that.
Tejas@perioimpl is offline   Reply With Quote
Old 26th December 2008, 12:16   #21
KSM-Vtec's Avatar
Thanked: 440 Times
Ya actually my setup is in a bad state and it is overdue for a long time now...ill go ahead with the work. Ya do let me know if the prices are ok.
Dan is going to call you, lets have a mini meet this afternoon.
Old 26th December 2008, 12:20   #22
Ya actually my setup is in a bad state and it overdue for a long time now...ill go ahead with the work. Ya do let me know if the prices are ok.
I think the price is fine, no problem. And done, we can meet today. i'm there till 4 o'clock.
Old 26th December 2008, 14:26   #23
Thanked: 103,541 Times
In the after-market, Sunil Shanbagh is a veteran whom I trust the most. His workshop is at Dadar - 2414.9910. High quality of work & an outstanding gentleman.
Old 27th December 2008, 21:00   #24
Sahil's Avatar
Thanked: 2,717 Times
To get work done at his place too ,GTO?
I have been sending my cars to him for over a decade, agree with GTO's views on him he truly is honest and knowledgeable.
Old 28th December 2008, 15:12   #25
GTO - Touring's Avatar
Yup, been visiting him since the college days. Thorough professional.
GTO - Touring is offline   Reply With Quote
Old 28th December 2008, 22:05   #26
KSM-Vtec's Avatar
Thanked: 440 Times
ok let me give him a call tomorrow and see what he has to say....
Old 30th December 2008, 17:11   #27
weejai's Avatar
I've been struggling to find a garage in Andheri (E) for OHC. Can anyone please suggest...
weejai is offline   Reply With Quote
Old 6th January 2009, 11:05   #28
KSM-Vtec's Avatar
Thanked: 440 Times
Thumbs up Suspension Problem Solved ! ! !
Ok. Have got the front suspension re-built from a suspension specialist (he claims to be one and for sure has enough work) close to my house called Oberoi Suspension, Bandra.
Replaced quiet a few parts since they were all worn-out(70k Kms old), got them myself from City Motor Co, Opera House.
Suspension Related Parts
Front Shocks - INR 3,800
Front Strut kit – INR 450
Lower Arms – INR 3,000
Linkage Bush Kit – INR 250
Balance Rod Bush Kit – INR 100
Steering Related Parts
Steering Ball joint – INR 1,000
Tie rod ends – INR 750
Other Worn-out Parts
Front Wheel Bearing – INR 1,400
Brake Pads – INR 650
Front Centre Engine Mounting – INR 850
Total Labour – INR 1,000
Grand Total – INR 13,250
Got the steering rack checked, not a single drop of oil has leaked and was told that its as good as new. The suspension rattles have absconded but there are other things I need to take care of. The interior door panels/plastic parts are rattling and I just don’t know what to do about them. Plz suggest a solution guys…..do you know of a guy who can do this for me?
Old 6th January 2009, 12:52   #29
The suspension parts are quoted for a pair or single?
How long did the mechanic keep the car with him?
About the rattles, i have been trying all sorts of ideas and nothing seems definitive. A few drops of stickfast in certain hidden areas have helped. Only other solution is to replace the plastic parts with new ones. If you do find a good person for this issue, let me know too!
Old 6th January 2009, 12:58   #30
KSM-Vtec's Avatar
Thanked: 440 Times
The rates are for pairs and not single...he had to keep the car for 3 days because the threading on one of the bolts was worn-out and it was a sunday. 2 days are enough for the job.
Problem with Vtec idling...varying RPM. EDIT : Solved! GTO Technical Stuff 99 22nd January 2017 16:48
Linea Diesel: No one is able to solve engine problem EDIT: Now solved ! Travelbug Technical Stuff 35 21st November 2013 23:39
OHC trouble after engine flush. EDIT : Now Solved! ankitahuja Technical Stuff 78 10th December 2012 16:52
Strange problem with my petrol Swift. EDIT : NOW SOLVED abhaybakshi Technical Stuff 50 11th June 2012 13:01
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 11:19
