Old 9th January 2009, 11:19   #46
sushrutha's Avatar
Thanked: 325 Times
Thanks shreays for the info. Will checkout the shop when I intend to replace my car's suspension.
OT: Well i do stay at south Bangalore - Padmanabhanagar
Old 9th January 2009, 11:34   #47
Dippy's Avatar
Thanked: 192 Times
Well done KSM
City Motors Opera House is the best place in Mumbai for OHC parts and if you know someone there he gives some discount as well. During my last service (the one where they crashed my car) they told me that brake pads were due for replacement and also that my brake discs need replacement. I asked them the estimate pat comes the reply 5000 for the brake pads and 15000 aprox for the discs.
Took the car to my trusted mechanic. There is absolutely no need for disc replacement. I got the brake pads changed cost me 950/- for the pads, they are made by KBX. Total expense including labour and disc cleaning and polishing came to 1400/- only.
My car goes to Honda only for service. For the rest I have my trusted mechanic. Hes not a road side types. His is a proper shop who also sells accessories and all his mechanics are in proper uniforms and badges with their names on it. I am actually glad I found a good mechanic which is realy hard to find these days.
Dippy is offline   Reply With Quote
Old 9th January 2009, 11:57   #48
lohithrao's Avatar
Thanked: 163 Times
Guys anyone has info on who is the supplier for "Fiat"??
lohithrao is offline   Reply With Quote
Old 9th January 2009, 12:21   #49
KSM-Vtec's Avatar
Thanked: 440 Times
Well i am sure you wont be surprised to know that it was Jitu who told me to get the parts from City Motors.
Got the parts fitted from a suspension specialist who luckily has a workshop next door...labour quality was good and charges reasonable.
In fact i also got my fuel tank & pump cleaned yesterday and the guy did a good job...but what we found inside was a sad story...
Well done KSM
KSM-Vtec is offline   Reply With Quote
Old 9th January 2009, 12:35   #50
asejwal's Avatar
Thanked: 15 Times
Default And what was found inside!?!
hey OHC Vtec bro, now what's the sad story about the insides??? Care to share!?!
asejwal is offline   Reply With Quote
Old 9th January 2009, 13:40   #51
KSM-Vtec's Avatar
Thanked: 440 Times
Ya sure but i thought i will save it for later when i can post pics...wouldn't that be more interesting?
Old 9th January 2009, 13:55   #52
iraghava's Avatar
Thanked: 156 Times
Dippy - OE pads are now available in the market for about 1200/- at least in Delhi. I've twice tried KBX pads but both times I faced squealing issues after the pads had done 10k odd kms.
I even took this up with a Bosch official at the Auto Expo (they had then acquired KBX) and he admitted it was an issue that they were trying to resolve and even if I had the pair replaced by them under warranty the issue would crop up again after a while.
But maybe, they've improved since then, do let us know how they fare for you.
Old 9th January 2009, 15:06   #53
KSM-Vtec's Avatar
Thanked: 440 Times
Default Brake Pads
Hey come now dont scare me ...i just installed the KBX, they look good as of now though. But the good thing is i bought them for only 650
Old 9th January 2009, 21:30   #54
mura's Avatar
Thanked: 27 Times
The cheap KBX pads work ok only in slow speeds , they fade very badly if you brake a couple of times from highway speeds and life is very bad - max 15k kms.
Infact those cheap "KBX" may not be KBX at all.
Most OE quality Brake pads will be about 1200 - 1500 Rs.
mura is offline   Reply With Quote
Old 9th January 2009, 23:29   #55
KSM-Vtec's Avatar
Thanked: 440 Times
Well i am not too sure if they are that bad because i have driven all the way from mumbai to BLR and back and at speeds over 160 at times, breaking was real good i must say.
Old 9th January 2009, 23:43   #56
I recently replaced the pads and discs in my city.Got original HONDA THAILAND spares, the discs costed me 2200/pair and pads 2800/pair.
badz is offline   Reply With Quote
Old 10th January 2009, 00:23   #57
KSM-Vtec's Avatar
Thanked: 440 Times
Default The OHC Suspension Rebuild - Photo Shoot
Now before you say anything...i know my car needs a good wash...
What is what??
OHC Suspension Problem EDIT : Solved!-08012009189edit.jpg
Zoom on to the Lower Arm..INR 3,000
OHC Suspension Problem EDIT : Solved!-08012009195.jpg
The Munjal Showa Shock/Strut...INR 3,800
OHC Suspension Problem EDIT : Solved!-08012009206.jpg
OHC Suspension Problem EDIT : Solved!-08012009209edit.jpg
OHC Suspension Problem EDIT : Solved!-08012009211.jpg
Every thing plunged in...
OHC Suspension Problem EDIT : Solved!-08012009212.jpg
OHC Suspension Problem EDIT : Solved!-08012009214.jpg
Ready to roll...vvrrrmmmm
OHC Suspension Problem EDIT : Solved!-08012009216.jpg
Before we started...
OHC Suspension Problem EDIT : Solved!-08012009192.jpg
OHC Suspension Problem EDIT : Solved!-08012009199.jpg
Old 10th January 2009, 00:42   #58
KSM-Vtec's Avatar
Thanked: 440 Times
Default THe Fuel Tank Clean Up - Pics
Like i said..here we go...
OHC Suspension Problem EDIT : Solved!-08012009218.jpg
This is the quality of fuel we get
OHC Suspension Problem EDIT : Solved!-08012009221edit.jpg
The fuel Pump..
OHC Suspension Problem EDIT : Solved!-08012009223.jpg
The pump . . . Clean and clear!!!
OHC Suspension Problem EDIT : Solved!-08012009224.jpg
OHC Suspension Problem EDIT : Solved!-08012009225.jpg
There was no way i was gonna put that fuel back into the tank..
OHC Suspension Problem EDIT : Solved!-08012009228.jpg
This is how dirty the tank gets when more than 7,000 liters of fuel passes thru it ..
OHC Suspension Problem EDIT : Solved!-08012009232.jpg
OHC Suspension Problem EDIT : Solved!-08012009222.jpg
KSM-Vtec is offline   (1) Thanks Reply With Quote
Old 10th January 2009, 12:33   #59
KSM-Vtec's Avatar
Thanked: 440 Times
Oh ya ...the fuel tank & pump clean up cost me only INR 500. The guys did a good job which contributed towards the preventive maintenance which is much needed with the kind of fuel we get here in India.
Old 11th January 2009, 11:16   #60
lohithrao's Avatar
Thanked: 163 Times
KSm thats a informative...thanks.
maannn i after seeing your fuel tank guess my cars tank needs cleaning too.......scary is the word!
OT..Fiat adventures lower arm cost 2200, 800 bucks lesser then Honda. wonder why people say fiats spares are expensive
Problem with Vtec idling...varying RPM. EDIT : Solved! GTO Technical Stuff 99 22nd January 2017 16:48
Linea Diesel: No one is able to solve engine problem EDIT: Now solved ! Travelbug Technical Stuff 35 21st November 2013 23:39
OHC trouble after engine flush. EDIT : Now Solved! ankitahuja Technical Stuff 78 10th December 2012 16:52
Strange problem with my petrol Swift. EDIT : NOW SOLVED abhaybakshi Technical Stuff 50 11th June 2012 13:01
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 11:19
