Old 11th January 2009, 12:24   #61
kutlee's Avatar
Thanked: 201 Times
thanks for sharing the pics. what was in the tank? new paper roll? cotton roll? not clear.
kutlee is offline   Reply With Quote
Old 11th January 2009, 16:09   #62
KSM-Vtec's Avatar
Thanked: 440 Times
are you sure? are they original OE?
Originally Posted by lohithrao View Post
KSm thats a informative...thanks.
maannn i after seeing your fuel tank guess my cars tank needs cleaning too.......scary is the word!
OT..Fiat adventures lower arm cost 2200, 800 bucks lesser then Honda. wonder why people say fiats spares are expensive
KSM-Vtec is offline   Reply With Quote
Old 11th January 2009, 16:10   #63
lohithrao's Avatar
Thanked: 163 Times
Originally Posted by KSM-Vtec View Post
are you sure if they are original ones?
yes, got the quote from a authorised ser center.
lohithrao is offline   Reply With Quote
Old 11th January 2009, 16:13   #64
KSM-Vtec's Avatar
Thanked: 440 Times
oh thats great...really dint think adventure parts would be that well priced..
Old 12th January 2009, 10:32   #65
KSM-Vtec's Avatar
Thanked: 440 Times
It was a 6" long twig ...can you guys believe that??? God knows how it got in there..
Old 12th January 2009, 11:50   #66
DieselFan's Avatar
Thanked: 234 Times
some disgruntled petrol pump employee or employee of the service station or a prankster in either of these locations. There is no other way this could happen.
DieselFan is offline   Reply With Quote
Old 12th January 2009, 18:48   #67
KSM-Vtec's Avatar
Thanked: 440 Times
Ya that could be the case but..the dirt in the tank shows how adulterated/dirty the fuel available in a city like mumbai is. I really wonder how bad the other cities are.
Old 12th January 2009, 19:02   #68
narayan's Avatar
Thanked: 1,338 Times
KSM - where is the front wheel bearing located ? I am having a doubt whether there really exists a FRONT wheel bearing ? I mean - why would the driven wheels need to have a bearing ?
narayan is offline   Reply With Quote
Old 13th January 2009, 09:54   #69
KSM-Vtec's Avatar
Thanked: 440 Times
The front wheel bearing is located inside this...well i am not sure why the driven wheels should not have a bearing...but what i know for sure is ITS THERE!!!
OHC Suspension Problem EDIT : Solved!-08012009199.jpg
Old 13th January 2009, 17:30   #70
shreyas99's Avatar
Thanked: 21 Times
Infractions: 0/1 (4)
Oh ya ...the fuel tank & pump clean up cost me only INR 500. The guys did a good job which contributed towards the preventive maintenance which is much needed with the kind of fuel we get here in India.
Hey KSM-Vtec, Nice pics and an eye opener to the quality of fuel we are filling in.
shreyas99 is offline   Reply With Quote
Old 13th January 2009, 17:34   #71
shreyas99's Avatar
Thanked: 21 Times
[quote=KSM-Vtec;1127903]The front wheel bearing is located inside this...well i am not sure why the driven wheels should not have a bearing...but what i know for sure is ITS THERE!!!
And Just to share, even the rear wheel bearings dont come seperate for Honda city. You need to buy the entire Hub. Not sure about other cars.
Old 13th January 2009, 18:31   #72
KSM-Vtec's Avatar
Thanked: 440 Times
Well i dont think so... i got the wheel bearing replaced and not the entire hub. Same applies to the rear wheel. The hub has to be sent to the tunner and he does the job...
Old 13th January 2009, 18:40   #73
narayan's Avatar
[quote=shreyas99;1128754]
I dont think so - unless ur mixing up the wheel bearing housing with the hub
Old 13th January 2009, 18:42   #74
shreyas99's Avatar
Thanked: 21 Times
Wow, this is news to me
I was given that info by Honda ***. He gave me a quote of 11k for the spare. When i checked for the same spare outside i was quoted 4500 INR.
How much did it cost you to replace just the bearing ?
Old 13th January 2009, 18:57   #75
im_srini's Avatar
Thanked: 397 Times
Exclamation
OHC Suspension Problem EDIT : Solved!-danglingcaliper.jpg
Hi Kaushik, it's usually advised that during brake & suspension work, calipers are not allowed to dangle like in the pic. The calipers can be pretty heavy & could place undue stress on the piping for the brakes.
im_srini is offline   Reply With Quote
Problem with Vtec idling...varying RPM. EDIT : Solved! GTO Technical Stuff 99 22nd January 2017 16:48
Linea Diesel: No one is able to solve engine problem EDIT: Now solved ! Travelbug Technical Stuff 35 21st November 2013 23:39
OHC trouble after engine flush. EDIT : Now Solved! ankitahuja Technical Stuff 78 10th December 2012 16:52
Strange problem with my petrol Swift. EDIT : NOW SOLVED abhaybakshi Technical Stuff 50 11th June 2012 13:01
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 11:19
