Old 26th December 2008, 11:23   #1
Default Scorpio - Poor air flow from AC vents
I am getting extremely poor air flow through the air vents inside the car. At setting 1 the flow is negligible. At 2/3/4 setting it is more but accompanied with lot of noise.
I recently replaced the air filter.
Anybody faced similar issues? Any suggestions?
Thanks,
Sash
sashb is offline   Reply With Quote
Old 26th December 2008, 12:22   #2
prabhuav's Avatar
Thanked: 112 Times
Check your vent controls. It might be stuck at closed.
Get your ventilation piping checked for leaks.
Are you having the same issue in recirculating mode?
Vijay
prabhuav is offline   Reply With Quote
Old 27th December 2008, 02:02   #3
Thanked: 660 Times
what has air filter got to with HVAC.
When was the vehicle purchased? i mean whats the model year.
Old 27th December 2008, 07:22   #4
Sankar's Avatar
Thanked: 4,649 Times
He must've replaced the HVAC air fiter, some cars do come with them.
Old 27th December 2008, 21:28   #5
wanderernomad's Avatar
Thanked: 805 Times
A common problem(?, I ahve not faced it but 3 of my friends have) with Scorpios. Get the vents opened and cleaned. The problem will go.
wanderernomad is offline   Reply With Quote
Old 27th December 2008, 21:56   #6
Thanked: 253 Times
Hey! What are we talking about here?!
What on earth is that filter supposed to do then?
I suspect this is the result of fresh air intake. ?? Does the fresh air go through the filter? I don't think so.
Somebody please enlighten!
anupmathur is online now   Reply With Quote
Old 27th December 2008, 22:44   #7
Thanked: 805 Times
Yes fresh intake clogs the filter and this in turn causes reduced air flow. Where is the confusion?
Old 27th December 2008, 23:02   #8
raj_5004's Avatar
Thanked: 2,064 Times
this is the reason not all cars comes with HVAC air filter. even in fresh air intake mode, it passes through the filter. after use in dusty conditions, you are supposed to clean the filter, else it gets choked resulting in low air flow from the vents.
but since sashb has changed the filter, i think it has more to do with the vent closing mechanism. it is always advisable to use the AC in re-circulation mode, once in a week you can switch it to fresh air intake to allow fresh air inside the cabin.
Old 28th December 2008, 08:26   #9
Thanked: 253 Times
If the filter is doing its job, how do the vents get clogged?
Old 28th December 2008, 08:40   #10
akshay4587's Avatar
Thanked: 1,686 Times
I had this problem in my Accent.
the blower would make a lot of noise and would give very less air.
Problem was sponge stuck in the filter.
Old 29th December 2008, 14:44   #11
Thanked: 805 Times
@anup: lolz mate I think you took it too literally. What I meant by getting the vents opened was to get the entire delivery system cleaned by reaching inside the vents. And for that you need to open them, mate.
Old 29th December 2008, 16:38   #12
Thanked: 253 Times
Wanderer, it's not about taking it too literally. Think about it. If the filter is doing it's job, there should be no reason for copious quantities of dust/dirt to go downstream and clog the vents.?
Am I missing something?
Old 29th December 2008, 17:19   #13
m-hawk's Avatar
Can you tell us where to look for the A/C filter ?
Thanx
m-hawk is offline   Reply With Quote
Old 29th December 2008, 17:37   #14
Thanked: 253 Times
Thanx
Open the glovebox all the way down by pressing the sides of the box to free the two stops. Once it is fully opened till floor level, unhinge it. Keep it aside.
Behind where the glovebox normally sits, you'll see a black rectangular 'door'/cover. Prise it open. Inside is the filter cartridge, which you can simply slide out.
Old 30th December 2008, 12:41   #15
Thanked: 805 Times
The route is through the filter and it gets clogged reducing airflow. That is the problem. Plus I have seen a lot of quantities getting accumulated downstream even when the filter itself is clogged to its gills. How beats me too. Maybe the force of air does get a few to escape the filter as it gets clogged? Maybe, but I am not sure.
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
DIY: Rear Air-Con Vents wanderernomad DIY - Do it yourself 73 23rd February 2015 10:17
Odd sound from Air-con vents mvaidy Technical Stuff 15 19th January 2015 07:45
Hot air vents out under the dash of my alto! please help sunil.nv Technical Stuff 7 26th February 2009 10:54
Air vents on the hood: a perf mod? agentsmith Modifications & Accessories 20 6th September 2006 03:50
