Old 18th April 2005, 01:37   #1
freakr's Avatar
Default help reg gear ratios
hi ..
i was wondering if someone could tell me about the gear ratios and the shift points . how are they tweakd ?
freakr is offline   Reply With Quote
Old 18th April 2005, 01:59   #2
turbo_lover's Avatar
http://www.howstuffworks.com/gears.htm
the link above should tell u everything about gear ratios .
shifitng point is different for each engine .. redlining the car each time does not give you a good run ... engine power curves down after a certain engine speed ...so look to shift by 85 - 90% of the tacho..
but it all depends run your car a few times .. too see what is the ideal shifting point ..
cheers
turbo_lover is offline   Reply With Quote
Old 18th April 2005, 10:08   #3
iceman91's Avatar
Thanked: 22 Times
you just want to know more about gear ratios?
well basically they are worked on in tandem with the engine thereby giving you faster initial and maintain the power throughout the revs at maximum.
iceman91 is offline   Reply With Quote
Old 18th April 2005, 10:14   #4
Vulken Auto's Avatar
Thanked: 54 Times
ah man gear ratios , not again. we had this design class in Engg, we calculated 3 page formula for opti gear ratios. Big head ache, any way cleared the exam in my first attempt so dont know much abt it
Vulken Auto is offline   Reply With Quote
Old 18th April 2005, 15:07   #5
jigarmuni's Avatar
well by what i know, it is not necessary to develop gear ratios for a better initial speed ... we can have ratios to give just top end speed also!! .... By the way does any Bhpian have a closed ratio gear box or a Sequential Box on their cars????
jigarmuni is offline   Reply With Quote
Old 18th April 2005, 16:53   #6
iceman91's Avatar
Thanked: 22 Times
closed ratio gearbox...had it on both the cars. teh e-zen as well as have it on the baleno
Old 18th April 2005, 17:19   #7
jigarmuni's Avatar
dude wanted to install one on my Vtec, any idea as to how much it will cost and from where i can get it??? And yeah, any drawbacks after installing da box???
Old 18th April 2005, 17:31   #8
speedsatya's Avatar
Thanked: 706 Times
as the name "close-ratio"suggests,the gearing will be short ,such that the revvs stay in the power band range throughout in all gears.
but i think the top speed will be reduced.
speedsatya is offline   Reply With Quote
Old 18th April 2005, 19:44   #9
freakr's Avatar
so is it like if you have close ratios the top speed goes down and the accelration is better.how much does the entire setup cost's.i dont think it would be suitable for a car which is used regularly...is it only meant for racing purpose ?
Old 18th April 2005, 20:00   #10
yeah ..close ratio is a performance setup .. the car is constantly in its powerband ...its a headache driving in city conditions ,mileage suffers aswell ..
but the fact that ur feeling that pull each time shift up is thrilling enough..my friend has a mazda MX6 .. came stock with a close ratio ... and a performance muffler .. feels great .. but sometimes it does get tiring the shift interval are short in the city you'll end up driving with one hand on the shifter all the time ..
Old 18th April 2005, 22:29   #11
jigarmuni's Avatar
yeah the top end will drop a little bit..... but then the acceleration is just too fabulous...! Infact ideally i would love to fit in a sequential box, but it will proabably cost me about 5-6 lacs! Will team-Bhp be interested in sponsering me???
Old 18th April 2005, 22:46   #12
old habits die hard
adilshah is offline   Reply With Quote
Old 18th April 2005, 22:49   #13
jigarmuni's Avatar
Originally Posted by adilshah
old habits die hard
hahaha, adil dude.... actually i am still waiting to get sponsered from somewhere, somehow....!!
Old 18th April 2005, 22:53   #14
well its good you keep trying. you will get lucky some time or the other.
i dont think a sequential is so expensive. are you sure dude.
Old 18th April 2005, 23:03   #15
jigarmuni's Avatar
yeah adil, infact vickey was planning to put a sequential box on the new formula car with esteem engine, and it was costing about 5lacs! It bloody costs more then the car itself !! Infact one of the JKtyres Rally car (Group A) had a sequential box i was told...! hehehhe and guess what???? Mr. Anmol breaks the Box....when he was driving on the streets of delhi!! hehehe
My new Gypsy so many questions - Changing the gear ratios mrgizzer Modifications & Accessories 6 28th August 2012 12:51
Gypsy Gear ratios MexXxentric 4x4 Technical 23 15th April 2011 20:56
Guide on gear ratios vikid 4x4 Technical 14 6th May 2010 15:41
About Gear Ratios & their Relation to Tyre OD, Torque, Speed etc speedsatya Technical Stuff 90 8th April 2008 11:50
What are gear ratios? sridhar24 Technical Stuff 8 1st March 2005 20:38
