Old 28th December 2008, 20:27   #1
Exclamation LPG on My Esteem heats up when used with a/c
Anybody has a solution for My LPG Esteem which heats up when used with a/c ?????
Ashok Kumar.T. is offline   Reply With Quote
Old 28th December 2008, 22:54   #2
Hashim's Avatar
Thanked: 32 Times
- Check radiator condition, get it cleaned or replaced if required. Use recommended quantity coolant.
- Make the radiator fan direct (short thermostat terminals).
- Your LPG kit maybe set for richer mix of lpg, get it set properly.
If still it heats then it will be a good idea to run it on petrol while you are using AC and later switch to LPG when car gets cooled or when not using AC at all.
Hashim is offline   Reply With Quote
Old 29th December 2008, 11:13   #3
Psycho's Avatar
Thanked: 95 Times
You are running lean with LPG.
New WagonR Duo OR Chevy Spark LS LPG OR Hyundai i10 LPG? Oxy Hatchbacks 39 24th August 2014 08:02
Santro GL LPG or Spark LS LPG arunjeetsingh Hatchbacks 13 28th April 2010 14:37
LPG car for my parents (Old Alto or new 800 LPG) jits_1998 Hatchbacks 7 9th October 2009 11:19
Palio 1.2 fitted with LPG Kit - Petrol level keeps coming down in LPG Mode shineshine Technical Stuff 9 10th May 2009 04:52
Wagon-R: VXi+LPG OR LXi+Upgrades+LPG? EDIT: Now booked LXi sohu9 Hatchbacks 14 16th January 2007 13:37
