Old 29th December 2008, 12:34   #1
Default Some Problems with my petra
This is regarding my Fiat petra ELPS 1.6 (40K Kms)It been a week since I noticed that the fan that gets turned on when the engine is switched off has not been working.
A second problem that has been there for a while is that there are white spots seen on the car. Last may I had my car polished at Tata service center. Does anyone know why I am seeing these white spots. Can the polish have caused this problem to appear. Or is it due to bad paint quality.
If I have to get it repainted can I go for another color and how much would be the approximate cost for a new paint job?
Thanks in advance for your suggestions and help.
shbhrao is offline   Reply With Quote
Old 29th December 2008, 15:21   #2
Thanked: 103,377 Times
Possibly due to the dip in winter temperatures?
Can you post pics? Neither polishing nor a bad paint job cause white dots. Most probably, the white dots have been caused by some painting work in your building.
Anywhere between 18,000 - 45,000 depending on quality & vendor.
Old 29th December 2008, 20:18   #3
Thanks GTO for your reply. I hope u are right about the dipping temperature.
About the white spots though, it is not external paint. I will try and post pics. It looks like faded white spots (like the kind that you see when you diwali fireworks are burnt in the floor. Puzzling.
Virus problems/spyware problems! post here! SirAlec Gadgets, Computers & Software 10 16th July 2014 00:05
Mahindra Scorpio CRDE 2007 - Problems 'n' Problems chandrda Technical Stuff 3 13th November 2009 09:59
Fiat Petra - Some Queries Rai Technical Stuff 15 7th May 2008 23:25
Tyres for OHC 1.5 + some small problems Andre Tyre & Alloy wheel Section 8 4th August 2006 08:50
