Old 2nd January 2009, 09:54   #1
Exclamation Gear shifting trouble in Getz
hello
we own a getz 1.3 for nearly a 1.5 years and has clocked 7000kms.The car is driven only by me and im no rash user.Off late there has problems in shifting the gear especially from neutral-1st gear.Its hard at times and sometimes its normal.I dnt find the same problem when shifting to other gears.Could you recommend some solutions for this
thanks
sathya_j2084 is offline   Reply With Quote
Old 2nd January 2009, 10:11   #2
Thanked: 15 Times
Are you trying to shift from Neutral to 1st in crawling speeds? If yes there should be no difficulty..
The first few shifts of the day in my Getz is always hard/rough, after that it is a delight to use.
PraveenM is offline   Reply With Quote
Old 2nd January 2009, 10:14   #3
Thanked: 31 Times
If the car is in extended warranty then go ahead and get it corrected from hyundai. It happened with my santro and i need to shell out 5K approx for that
Check for lubrication. But Getz gears are very very smooth atleast when i compare with my SX4
aka_iitd is offline   Reply With Quote
Old 2nd January 2009, 11:41   #4
Default Butter smooth
Sathya, I have been using Getz for almost 4 years. I have nothing but praises for it's gear shift quality. I would say it's one of the best I have ever used (Better than 3 times expensive Embera) and still working flawless after 50k 4 years use.
rohitrk is offline   Reply With Quote
Old 2nd January 2009, 16:46   #5
Nikhilb2008's Avatar
Thanked: 6,651 Times
I agree. It is a delight to use.
Our Getz is just 5500 kms old, but it is so awesome!!
Please go to your usual Hyundai service centre and get it corrected.
SWIFT - Shifting to 2nd gear problem eflanker Technical Stuff 45 31st January 2009 16:49
Car banged. Gear shifting problem! maxbhp Technical Stuff 15 15th September 2007 12:48
Tachometer vs Engine sound. What do you prefer more while gear shifting? salilpawar1 The Indian Car Scene 74 25th April 2007 15:40
Future of gear shifting naveendhyani Technical Stuff 1 22nd April 2006 02:22
Automatic gear shifting intervals shahmotors Technical Stuff 10 9th June 2004 13:22
