Old 2nd January 2009, 22:48   #1
shreyasma's Avatar
Default Esteem BS III Clutch issues
Hello friends...
Need a lot of advise from you all.
I have an esteem 2005 bsIII model...The problem on this version of esteems is its clutch which can irritate the driver to the core.
Due to the norms of BSIII there is dome design chane that effects the clutch mechanism (Thats what i have heard from the Maruti guys and practically faced).
Problem: You have to accelerate a bit more than the normal cars and only then release the clutch lever to put the vehicle in motion. If the sequence is not right then the entire vehicle vibrates like hell.
I drove other BSIII Esteems (4 Nos to be precise) and still noticed the same issue. However, all other esteems are absolutely fine.
Is there a workaround for this problem?? Have any one faced this isuue if not irritated as i am?
Your advises are precious...
shreyasma is offline   Reply With Quote
Old 2nd January 2009, 23:28   #2
salvation's Avatar
Thanked: 11 Times
well i didnt get you there. When you noticed the same issue in other esteems you drove how can you say they are fine.
i have a 2007 esteem and i have not encountered any such shuddering of vehicle.
salvation is offline   Reply With Quote
Old 3rd January 2009, 02:37   #3
adi99's Avatar
Didn't really understand what you were trying to say?!
Did you try adjusting the clutch play?
adi99 is online now   Reply With Quote
Old 3rd January 2009, 06:39   #4
i have a 2002 mpfi esteem and i think i know what you are talking about. if you don't play the clutch and accelerator properly the car shudders like hell, however it's not a behaviour much different from other cars.
vishalpipraiya is offline   Reply With Quote
Old 3rd January 2009, 09:00   #5
shreyasma's Avatar
I am sorry to have confused. When i say all other esteems, i mean BS II and other models except the BSIII variant.
Have tried the clutch play. But this doesnt correct the problem but just made it a little better. How much ever better it is you still have to accelerate before releasing the clutch
Old 7th January 2009, 14:09   #6
ilangop's Avatar
Thanked: 591 Times
Hello friends...
I guess you are comparing your esteem with the older carburetted one. Yes, you ll feel like you are pedalling an under powered engine. The MPFI engine probably delivers lesser fuel per cycle to meet the BS-III norms. If possible compare the power and torque delivered, and fuel economy by these 2 versions. The carburetted version would give a lesser fuel economy, meaning more fuel per revolution - more chemical power - less you press the gas pedal.
I dont think of any need to change the clutch design unless the transmission systems are different.
Alternatively, if ever you have an opportunity to run you esteem with a gypsy's ECU (assuming that the Gypsy's ECU is tuned for a SUV performance) you should feel the difference since the engines are the same in both.
ilangop is offline   Reply With Quote
Old 7th January 2009, 19:12   #7
shreyasma's Avatar
WOW!!! I didnt know that...now the hunt starts for a gypsy ECU
Old 11th January 2009, 11:52   #8
shreyasma's Avatar
Friends, Help me sourece a Gypsy ECU that suits the esteem.
Your info on the price also appreciated for me to decide the change.
Old 20th January 2009, 15:24   #9
Psycho's Avatar
Thanked: 95 Times
Check the clutch plates alignment, that is what causes the shudder.
Old 20th January 2009, 16:13   #10
shreyasma's Avatar
Man gimme details where i can get this done...
i dont want to go to MASS..i already know their answer
Old 20th January 2009, 17:08   #11
rr_zen's Avatar
Thanked: 268 Times
I have a 2003 Esteem BSII and yes I must admit that the clutch is very sensitive and if not synchronised with the accelerator will definitely give those irritating shudders and might stall as well. I have had M.A.S.S change the cover assembly once under extended warranty after my repeated complaints however that didnt help much.
Also I was told that this is common in all MPFI cars that you need to accelerate more while releasing the clutch in first gear for the car not to stall.
rr_zen is offline   Reply With Quote
Old 21st January 2009, 10:55   #12
shreyasma's Avatar
Yes bro...apart from clutch and the power window issue...i am happy with the rest..
Suzuki Baleno (Type-III/Euro-III) Oxygen Sensor Info sarbashishb Technical Stuff 12 17th September 2015 09:26
Pajero BS III or IV EDIT - Bought BS III maheshramaling SUVs, MUVs & 4x4s 61 24th September 2012 11:36
Green Cotton /CAI/K&N typhoon for type-III esteem viky_s Modifications & Accessories 3 10th August 2009 11:19
Projector setup for Esteem type-III viky_s Modifications & Accessories 12 3rd August 2009 12:06
Bharat Stage III issues johnjacob The Indian Car Scene 6 3rd March 2005 10:50
