Old 3rd January 2009, 06:11   #1
Sush's Avatar
Default Logan Odometer reading correctness
Hi Guys,
I have a Logan 1.6 GLS. I occasionaly drive on the GT road (From Noida to Chandigarh). Earlier I used to drive on the same route in an esteem or a santro. The distance traveled reading used to be near about same.
However, on a trip in the Logan (although I took a slightly different route), I found out by some calulations that the reading shown was atleast off by 15-20 Kms for the same distance.
Has any other Logan owner observed this behavior or is it my misconception?
regards,
Sushant
Sush is offline   Reply With Quote
Old 3rd January 2009, 07:13   #2
thirst4torque's Avatar
Are you using stock tires?If you are not, then check for the tire size.
thirst4torque is offline   Reply With Quote
Old 3rd January 2009, 09:12   #3
Sush's Avatar
I am using the stock tyres only.
Old 3rd January 2009, 11:16   #4
vnabhi's Avatar
Thanked: 1,317 Times
I face the same problem with my WagonR. When compared to my M800, for every 21 kms on the Maruti, the WagonR showed a reading of 20 kms (5% variance). When I asked the dealer, he said the WagonR had a digital odo which was more accurate.
But when I bought a Fiesta 7 years later, the odo tallied with the M800. Even the Fiesta has a digital odo. So now I know the Maruti dealer gave me bull**** regarding the WagonR's odo.
With a 5% error, a travel of 400 kms will be off by 20 kms, which is acceptable, given the above circumstances.
Old 3rd January 2009, 11:41   #5
You should try comparing it with a GPS device and you will get to know the facts, both about the speedo as well as odo.
WanderNomad is offline   Reply With Quote
Old 3rd January 2009, 15:37   #6
speed0mania's Avatar
a +/- 5% error is taken within permisible limits AFIK!
speed0mania is offline   Reply With Quote
Old 3rd January 2009, 15:43   #7
siddartha's Avatar
Thanked: 24 Times
so you will be getting more kilometers per litre of fuel , why complain? ha ha
siddartha is offline   Reply With Quote
Old 3rd January 2009, 18:44   #8
vnabhi's Avatar
Exactly! That is how I console myself cheers:
Old 3rd January 2009, 19:02   #9
Thanked: 146 Times
Talk about pessimists, you guys take the cake!
HappyWheels is offline   Reply With Quote
Old 22nd February 2009, 21:27   #10
9tMax's Avatar
Thanked: 74 Times
Originally Posted by Sush View Post
Hi Guys,
regards,
Sushant
Is your logan showing a greater distance than the other two cars?
I also felt that my logan is showing a bit higher distance between the same pair of points after I switched over from my omni.
Like, a trip which used to be 130 km on my omni, comes to 150 km with the logan and that's almost a 15% jump.
9tMax is offline   Reply With Quote
Old 23rd February 2009, 09:49   #11
gemithomas's Avatar
Thanked: 138 Times
Is that the reason for the tremensous F.E figures of the Logan @ above 25km/l
Old 23rd February 2009, 12:30   #12
vnabhi's Avatar
Can't rule out the possibility! Another possibility is to faciliitate inflated taxi bills to make the taxi-owners a happy lot
Old 23rd February 2009, 12:39   #13
Thanked: 149 Times
Ah. Now we know why the Logan is popular with fleet operators.
Old 24th May 2009, 08:15   #14
Sush's Avatar
I could not check the odometer reading again. 2 months after buying the car, I had to move to New York. I will be returning in December and then will check it again.
Has anyone else faced the same issue?
9tMax, did you raise this issue during the servicing?
Highest reading in the odometer! Surprise The Indian Car Scene 602 18th April 2018 19:39
Odometer suddenly started showing a lower reading! kippu Technical Stuff 7 28th July 2017 10:14
Tyre Upsize: Impact on Odometer / MID reading drive_or_die Technical Stuff 7 29th May 2014 09:34
Odometer Reading: How to tell if it has been tampered with? nd81 Technical Stuff 58 8th September 2011 21:18
SuperBike Trip Reading shows 866 while ODO Reading is 865 freakrz Superbikes & Imports 3 23rd June 2009 11:57
