Old 3rd January 2009, 15:55   #1
Default Power steering issue in Alto
Hello Friends,
I was on a weekend drive outskirts of Mysore.
My car went through a bump at about 30 kmph, after that I am feeling hard steering especially at higher speed.
Mine is Alto-Lxi (with power steering, 2 Years) and I could feel now there is some resistance.At higher speeds , the steering used to be silk smooth.
Any inputs what might have went wrong?
I am not comfortable for now taking it to a service station, Its excellently maintained and had never seen service station except for regular servicing dues.
Kindly suggest.
Shirish.
shirishindurkar is offline   Reply With Quote
Old 3rd January 2009, 18:49   #2
Thanked: 146 Times
First suspect would be the fuse. Did you check that? Had a similar issue and turned out to be the fuse.
Apart from that, if there is something wrong, then you do need to take it to the service center for a through check up.
HappyWheels is offline   Reply With Quote
Old 4th January 2009, 11:54   #3
GTO - Touring's Avatar
I'd also get the steering rack & mounts checked.
GTO - Touring is offline   Reply With Quote
Old 4th January 2009, 19:59   #4
Thanked: 660 Times
any vibration you are feeling on steering on higher speed.
BTW! does not PS should feel bit harder on higher speed?.
Old 5th January 2009, 20:03   #5
Thanks Friends, I would get my car checked up at MSS.
SirAlec, yes I agree with you PS should feel bit harder at higher speed because the PS disengages beyond 40kmph, but I could feel its still harder than what it used to be.
Actually even though PS disengages, for Alto, I observed its still very light at higher speeds, probably Alto being relatively a lighter car.
Thanks again,
Shirish.
Old 5th January 2009, 22:31   #6
humyum's Avatar
Thanked: 2,503 Times
Get your alignment checked..maybe its out of alignment and hence the harder effort required to steer once the PS disengages.
Old 5th January 2009, 22:43   #7
Vid6639's Avatar
Thanked: 21,086 Times
Simple way to check if the power steering is working. With ignition off and on is the power required to turn the steering the same?
If the car is off steering will be heavy as the power steering is switched off. When engine is running the EPS turns on and the steering will be light. If this is not happening then your PS fuse is blown or some problem with EPS. If the steering is light with engine on but still not as light as before get the suspension and rack checked.
Power steering issue in my Swift VDI DieselFan Technical Stuff 23 17th May 2013 00:15
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
water inside sx4 - power steering issue ravindra_hyd Technical Stuff 11 16th September 2010 20:19
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
