Old 4th January 2009, 12:24   #1
Thanked: 441 Times
Default Engine replacement for Indica V2 petrol
This is my first post
My Indica V2(2002) Petrol engine blew up due to the failed water pump when my family was going to Yercaud. My mechanic(not a TATA ***) says that a fairly new 2008 second hand petrol engine is available in Pudupet(Pudupet is the place in Chennai where one is supposed to get all sorts of second hand components) with the ECM and complete wiring and I can replace the blown engine with this.
I know that the engine capacity is changed in the current petrol Indicas and is different from my 2002 model and therefore I am not sure if this is workable solution and would appreciate if any of you can guide me on this.
Arul
arulpeem is offline   Reply With Quote
Old 4th January 2009, 13:47   #2
Thanked: 245 Times
I would suggest you goto a T.A.S.S for this , instead of a local mechanic.
Check reconditioned engines by TATA with 6months/ 50k kms warranty. You might also check if they can do a Petrol>Diesel exchange (if you want to).
Old 4th January 2009, 19:53   #3
Thanked: 660 Times
Originally Posted by arulpeem View Post
Arul
What is the cost that he quoted.
Old 5th January 2009, 12:54   #4
Thanked: 103,410 Times
How many kms up? Always a good practice to change the timing belt + water pump together at 60,000 - 70,000 kms in most Indian cars.
Old 5th January 2009, 14:11   #5
im_srini's Avatar
Thanked: 398 Times
Exclamation
Hi Arul, could you elaborate on 'blew up' ? Most, if not all, modern engines are pretty good at taking care of themselves & the problem might not be severe enough to warrant an engine change.
Something similar happened to me recently when the upper heater hose in my car (2001 Alto) split, leaking coolant. However, my engine shut down even before the temperature gauge was in the red
Please have your car checked at an authorized service center. Pudupet could look like Wonderland, but you need to know what you're doing or you could be taken for a ride...
im_srini is offline   Reply With Quote
Old 5th January 2009, 14:16   #6
How much has your car done? Was timing belt changed as per schedule?
hrag is offline   Reply With Quote
Old 5th January 2009, 17:12   #7
Thanked: 441 Times
Hi thanks for the update. I was unaware that TATA reconditions engines. I will check it out with the dealer in Salem where my car is now stuck.
He has quoted 14k and I have to give him my blown engine
Rgds
Arul
It has done about 58,000KM. And I had not yet changed the timing belt.
Rgds
Arul
Note from the Team-BHP Support: Please use the "edit" button if posting within 15 minutes of the first post, instead of creating another back-to-back post
Also use "Multi Quote" option for quoting Multiple posts.
Last edited by Jaggu : 5th January 2009 at 17:50. Reason: back to back post, multi quote
Old 5th January 2009, 17:30   #8
Thanked: 441 Times
Hi Srini,
The whole episode happened just before Yercaud where my family was traveling(I was not there). The driver unfortunately had not noted the raising temperature gauge at all and only by noting the smoke from the enginehe stopped the car. The firewall had caught fire and fortunately it was a small one. He had managed to start the car and reach Yercaud. After bringing the car to Salem the car had been taken to a known mechanic who checked various things they have found the water pump had failed and the final result is that the head is bent by a millimeter.
As suggested I am looking at the TATA reconditioned engines
Rgds
Arul
58000 KM and I have not changed the timing belt
Old 5th January 2009, 23:23   #9
Thanked: 660 Times
how many kms was done in that 2008 indica.?
what exact he is saying about your engine. What parts are gone kaput. Can you please give the details.
Tata Indica Petrol : Engine size / Power / FI changes over time? FourWheelDrift Technical Stuff 3 6th April 2013 20:05
Engine Missing problem with Indica V2 LSi(Petrol) aavi Technical Stuff 7 12th November 2008 17:15
Small-engine Indica @ Rs 225,000, Indigo XL DICOR and Petrol 100bhp rkg The Indian Car Scene 47 2nd January 2007 22:46
