Closed Thread
Old 24th April 2005, 23:39   #16
Deeps's Avatar
Thanked: 68 Times
Ok so its quite a simple job. But then, can it be ignored? Apart from making the steering a bit stiffer, i am guessing it'd also slightly damage the belt if left untreated, right?
Deeps is online now
Old 25th April 2005, 10:32   #17
tsk1979's Avatar
Thanked: 16,421 Times
Dunno about that. But loose bolts can come off and cause more damage. Better get this fixed. The guys at Tata first tried tightning the AC belt, then the Alternator belt. Finally they took out the AC belt and then listened. The noise still came. They sad if the bolt comes off the Power steering assembly can get severly damaged.
tsk1979 is offline
Old 25th April 2005, 14:35   #18
Deeps's Avatar
Thanked: 68 Times
But is loose bolts the only cause of the belt slipping? And does the belt need to be replaced after a certain interval anyway?
Deeps is online now
Old 25th April 2005, 19:54   #19
normally_crazy's Avatar
Thanked: 394 Times
Fellas,
Instead of speculating here what is causing the problem , why not take the extra effort and simply get the car checked by a authorised service center ?
As it is , quite a few people here have given suggestions that might help in talking to the service center guys .....
so - take the car to the service station - give a demo of the problem and take it from there.....
cheers
normally_crazy is offline
Old 25th April 2005, 22:42   #20
Rudra Sen's Avatar
Thanked: 4,294 Times
Pankaj, I suggest you go (unless you've already done that) to an authorised service station and sit on their head till you get your problem out.
This thread is closed.
Rudra Sen is offline
Closed Thread
Resolved: Santro Power Steering Noise ghpk Technical Stuff 11 31st August 2016 14:22
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
Please suggest - power windows, power steering from one Esteem to another pramodkumar Technical Stuff 4 1st September 2006 09:19
