Old 13th May 2006, 17:48   #31
DCEite's Avatar
Thanked: 607 Times
Originally Posted by revharder
my 80K old santro still gives me 12-13KMPL with 110% AC in delhi traffic!
110%, because in delhi one has to stop much more on redlights and in traffic jams, then moving in his car!
on highways, it gives about 18-19kmpl with 100% AC and speeds in range of 90-100kmph.
At what speeds do you change the gears ? 12-13kmpl sounds real good with 100% AC in city traffic.
Although mine is a WagonR but i guess the gear ratios are quite similar.. maybe you can help me get better FE out of my car... i am really not satisfied with the 11 kmpl i am getting with 70% AC these days. (Being a maruti suzuki it should actually give more than a santro)
dont hae a tachometer, so i change according to speedo:
2nd at 15~20kmph
3rd at 25~30kmph
4th at 45~50kmph
5th at >60kmph
DCEite is offline   Reply With Quote
Old 13th May 2006, 18:07   #32
extreme_torque's Avatar
Thanked: 1,489 Times
Well my Palio runs close to 250 kms on fuel (speed) worth 1000 rs with ac on 70% of the time and 100% city traffic!
extreme_torque is online now   Reply With Quote
Old 14th May 2006, 00:08   #33
aZa
aZa's Avatar
Thanked: 17 Times
dceite : I think wagonR is slightly better than santro in the FE department. u SHUD get more than 11kmpl in city with a/c. Try shifting to 5th around 50ish speed and keep the speed between 50-60kmph this shud better ur FE figures
Old 14th May 2006, 00:43   #34
nitrous's Avatar
Thanked: 285 Times
And i thought the 9kpl with AC from my 1.3Litre ikon was bad.
nitrous is offline   (1) Thanks Reply With Quote
Old 14th May 2006, 11:52   #35
revharder's Avatar
Thanked: 49 Times
2nd at 15~20kmph
3rd at 25~30kmph
4th at 45~50kmph
5th at >60kmph
okay.
i doesnot follows speeds and all for changing gears.
since santro to doesnot have tacho, i'll try to give you some speed figures at which i changes gear, but i really never ever bothered to look at the speedo while driving!
2nd at 10~15kmph
3rd at 30~35kmph
4th at 45~50kmph
5th at 45~50kmph
yes!, keep same speed as in 4th and then shift to 5th, no need to increase speed just to get into 5th!
santros and wagonRs can very well keep cruising in 5th at about 50kmph all day with AC!
just some additional tips:
never accelarate and brake in a hurry, try to acclimatise wit the traffic around you and drive accordingly.
try to keep yourself in 5th gear max. no need to downshift to 4th or 3rd to gather speed. just press acc. pedal gradually and it'll gain speed gradually!
after sometime, you'll be enjoying that chore of keeping sustained 50kmph!
believe me, keeping a sustained 50-55kmph in 5th gear is much more difficult than hitting 100kmph in 3rd gear!
revharder is offline   (1) Thanks Reply With Quote
Old 10th December 2012, 22:26   #36
ravradha's Avatar
Thanked: 105 Times
Angry Re: santro xing xp 9 kmpl ..help
sorry reviving an old thread. Before I wanted to post, I wanted to check teambhp about Santro's mileage. This thread had the title which I wanted to give.
I got my 2003 Santro serviced - Engine oil, other oils and filter, changed. Got Turanza boots. The car drives like butter - but the mileage is only 9! This is in Chennai city - I cross 2 toll gates and 2 big signals in 10 km span. Out of this 5 Kms is in cramped traffic.
I'm not the best of drivers but I don't drive on clutch, I use proper gears, and don't break much, and on comparitively open roads do only 50 - 60 Kmph.
Got it checked at V3 Hyundai. They say the car is perfect and mileage of 9 is normal.
Do I have any options to increase efficiency?
ravradha is offline   Reply With Quote
Old 12th December 2012, 09:17   #37
1self's Avatar
Thanked: 270 Times
Default Re: santro xing xp 9 kmpl ..help
You can increase efficiency by:
1. Get a PROPER machine de-carb done (from the dealership). Both on the engine & intake manifold. You will be surprised with the amount of gunk that can build up on the intake valves & intake manifold, thanks to the crankcase ventilation system & intake charge reversion.
2. Get synthetic oil (5w-40) or, at least thinner (10w -30) mineral oil.
3. Get your clutch checked. You could be over-revving (beyond what is necessary) to get the car moving if you have a worn-out clutch.
4. Change the gear-oil in the gearbox. It can be surprisingly effective (from personal experience). You do get synthetic gearbox oil (75w-90) from Hyundai dealerships. It's expensive though.
5. Use less A/C.
6. Put more air in your tyres (10% more than recommended is good).
7. Remove any unnecessary weight from your car. I've seen people carry lots of weight in the boot like old newspapers (to be sold to the raddiwala), extra oil, heavy toolboxes, extra stepney etc. In short, if you don't need it on a regular city commute, DON'T lug it around!
8. Check if the gas station attendant closes the fuel cap tightly after a fillup. Sometimes they don't do that & petrol evaporates FAST at ambient temperature!
1self is offline   (1) Thanks Reply With Quote
Old 12th December 2012, 09:29   #38
ghodlur's Avatar
Thanked: 2,438 Times
Smile Re: santro xing xp 9 kmpl ..help
Couple of options you can try:
1) Change the fuelling station.
2) Try System G during refulleing.
3) Check the tyre pressure are correct.
4) If possible check whether you get the same efficiency at a different commute time or route.
ghodlur is offline   (1) Thanks Reply With Quote
Old 12th December 2012, 09:47   #39
9thsphinx's Avatar
Thanked: 468 Times
I don't know if people agree with this but Hyundai's are never known for their average - at least the petrol engines. We've had the Santro Xing XG since 2003 and it consistently gives an average of 10-12 in the city (on petrol), no matter how well driven! The rather new i20 petrol in our stable is no hero either.
Word of advice - if you live in a town where alternate fuel (CNG) is easily available, convert your Santro to CNG and you'll immediately start seeing savings. On CNG our Santro runs at ~ 2 - 2.5 Rs/km with the A/C on most of the times. The Santro has a very torquey machine, so the lag due to CNG is also very minimal. All-in-all its a win-a-win!
9thsphinx is offline   Reply With Quote
Old 12th December 2012, 09:53   #40
Catalyst_delhi's Avatar
Thanked: 149 Times
My mom's Santro Eco LPG and petrol gives around 9kmpl as well. I am stumped. It is a 2009 model always serviced at the dealer.Cleaning air filter helped a bit but the dealer says the car is perfect. Do tell me if you were able to increase your mileage.
Catalyst_delhi is offline   (1) Thanks Reply With Quote
Old 24th December 2012, 18:14   #41
ravradha's Avatar
Thanked: 105 Times
I'm running at more than 10 Kmpl now.
Old 24th December 2012, 18:58   #42
StrangeWizard's Avatar
Thanked: 229 Times
I never get more than 10 kmpl in my Spark.
Only on long drives on National Highways with maintaining 70-80 I get 14-15kmpl.
90% of my driving is in the maddening traffic of mumbai with 100% AC.
I rev the car only on open stretches.
This is how I shift gears :
2nd- 10kmph(normal) - 15kmph(revving)
3rd- 30kmph(normal) - 65kmph ( revving)
4th- 45kmph(normal) - 110 kmph (revving)
5th- 55kmph(normal) - Lol
I have done engine de-carb at the a.s.s
My car takes in 43 litres and on an average I drive 440-450kms on a full tank.
Only once I managed 650 kms on a single tank because 90% of it was on empty highways.
StrangeWizard is offline   Reply With Quote
Santro mileage dropped to 7 KMPL, why? sidindica Technical Stuff 12 13th November 2013 20:37
New Santro Xing vs old Santro Xing (eRLX) DCEite The Indian Car Scene 3 21st May 2012 21:48
Urgent help needed. please help-Santro Xing not starting iron.head Technical Stuff 3 12th May 2012 08:27
One question about tyres of Old Santro and New Santro Xing DDGuy Tyre & Alloy wheel Section 5 12th November 2008 13:35
4 kmpl palio 1.6???? HELP!!! sajeeth Technical Stuff 66 6th October 2008 20:11
