Old 13th January 2009, 00:34   #1
gaurav_diavolo's Avatar
Thanked: 53 Times
Default Can Steering fail in modern cars????
I make frequent trips to delhi and sometimes my speeds are 130-140 on the highway. Today while speeding my car, for a few second I felt as if there is something wrong with my steering (s*** scared!) and I pulled over. Then I wanted to know that is it actually possible to get the steering or brakes failed coz at these highway speeds I guess this would be the biggest nightmare with deadly outcome. Like we see in a lot of old movies that steering doesnt work or comes out in the hero's hand and brakes fail
Its stupid but still I am curious to know if these steering total failures or brake failures happen in cars like Ikons or Accents or Lauras. but I am curious to know.
gaurav_diavolo is offline   Reply With Quote
Old 13th January 2009, 09:32   #2
yes it is possible for steering or brakes to fail but not in the way they are shown in movies. there may be total failure if the components are not checked regularly.
harry2223 is offline   Reply With Quote
Old 13th January 2009, 09:49   #3
me_sid's Avatar
Thanked: 182 Times
Any mechanical/ Hydraulic/Electrical system are bound to fail, unless you take care of it and do preemptive maintainance. Would you please explain what actualy happened during speeding, did the steering feel a little heavy? In my esteem vx once I had a failure of the power steering the pipe burst, though steering was very heavy but steerable none the less.And I had to drive around 70 odd kms to reach my mechanic
me_sid is offline   Reply With Quote
Old 13th January 2009, 10:35   #4
drvhplyevraftr's Avatar
Thanked: 16 Times
Are the chances more to fail if I fit an after market steering wheel?. I have been always interested in momo steering wheel because of the smaller size (when compared to the huge steering wheel in Getz) but always had the fear that it might fail some time. Is it recommended to stay away from after market steering wheels?.
drvhplyevraftr is offline   Reply With Quote
Old 13th January 2009, 11:22   #5
Thanked: 244 Times
Mostly its the oil leakage due to failed seals which inturn fails the brake or steering.
Old 13th January 2009, 11:30   #6
ByDesign's Avatar
Thanked: 240 Times
well, since conventional steering systems use a rack and pinion linkage which is purely mechanical, failure depends on quite a few points doesn't it? Also, power assisted rack and pinion systems have a greater chance of failing due to an added electrical system. Steering systems need to be checked (how regular I do not know exactly, it depends on the car and the type of system used).
Good while driving man. Stay safe
ByDesign is offline   Reply With Quote
Old 13th January 2009, 16:13   #7
ImmortalZ's Avatar
Thanked: 139 Times
The steering wheel as it is isn't a component which will cause catastrophic failure simply because it's a wheel bolted onto a shaft.
It may contribute to wear and tear because with the new easier to use steering wheel, you might be driving more aggressively.
One reason to stay away is of course, the lack of an airbag.
Old 13th January 2009, 16:21   #8
sbasak's Avatar
Complete failure of steering suddenly is highly unlikely. I think there is a law which states steering must be mechanical (can't be steer by wire). The power steering might fail but you should still be able to steer albeit with much greater force.
sbasak is offline   Reply With Quote
Old 14th January 2009, 09:31   #9
me_sid's Avatar
Thanked: 182 Times
No way drv, you can safely dump your worries. Getting an aftermarket steering wheel which would result in a failure is a near impossibility. As I have mentioned its because of the pipe, seal and electricals, so make sure you regularly check your cars, and she will be Aok.
Old 14th January 2009, 13:46   #10
Thanked: 89,308 Times
Steering & braking mechanisms have the least chance of failure; car manufacturers adopt several quality checks to ensure this. Not surprising if you consider how vital their basic functioning is to safety.
Old 14th January 2009, 13:54   #11
Thanked: 47 Times
exactly! that is why steering and brake mechanisms have to be mechanical compulsorily, and can be assisted by other electrical/hydraulic systems. also the steering column must have direct (solid) mechanical link to the steering mechanism (rack/pinion)
parking brakes still are not hydraulic . they are still operated-by-wire (i don't know if any car has rod operated ones)
Xeno is offline   Reply With Quote
Old 12th February 2009, 09:27   #12
Thanked: 43 Times
i have a momo steering on my Getz, and have been using it for the last 2 years. My daily drive is almost 80 kms and mostly on the highways at speeds of around 100+ but so far i did have not faced any problem like steering failure. Infact the momo smaller dia steering has made the steering more responsive apart from giving a sporty look to the interiors.
sanjz is offline   Reply With Quote
Old 12th February 2009, 11:53   #13
greenhorn's Avatar
Thanked: 1,317 Times
somebody had posted the PS on a swift dzire failing during a TD and crashing it onto a divider or something.
Possible scam - Modern Fuel dispensers can be wirelessly reprogrammed at will batterylow The Indian Car Scene 5 10th July 2014 07:57
Can Airbag deployment fail due to damaged sensors ameaa Technical Stuff 16 28th May 2012 17:39
Can old school designs (not chassis) be made according to modern safety standards? petroguzzler Technical Stuff 8 14th May 2011 18:11
Can highway Fuel filling damage modern diesels? tsk1979 Technical Stuff 38 17th July 2008 16:03
60% of cars fail proposed fuel-efficiency norms? pjbiju The Indian Car Scene 27 17th March 2008 20:45
