Old 14th January 2009, 11:28   #1
gaurav.28ch
Posts: n/a
Default Esteem steering - vibrations and heaviness
After doing wheel alignment of my 2001 Esteem VXI, steering is vibrating and also feeling heavier at low speeds. Though feels a bit lighter at higher speeds. Also heaviness fades away when the steering is rotated counter clockwise. What could be the issue here. No such issues faced before wheel alignment.
Old 14th January 2009, 15:00   #2
Raccoon's Avatar
Thanked: 105 Times
I dont know why it should feel heavier, but if its vibrating you should immediately go to another alignment shop and re-check the balancing and alignment. Make sure you note the difference, to determine if and how much the last place goofed up.
Fiat Punto MJD - 24000 km- Heaviness Issue-Resolved, Car Under Testing magnanimousdude Long-Term Ownership Reviews 46 2nd February 2017 08:26
Invader 4x4 : Hard steering and steering box leaking DirtyDan 4x4 Technical 26 26th April 2013 13:30
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Getz CRDi - Steering Vibrations anarchist Technical Stuff 20 30th August 2009 12:50
Optra - steering vibrations over 80 km/h Boom Shiva Technical Stuff 10 23rd May 2006 11:58
