Old 15th January 2009, 03:36   #1
tush's Avatar
Question Swift DDIS Engine Starting Problem
Hello Friends,
Today at night, at about 2:30am when i turned on the ignition and after certain lights on the odo which are supposed to turn off, when they turned off i attempted to start the engine. This first attempt the engine failed to start. Waited for 5 seconds and attempted to start, it failed again, it did the same third time and was successful to start only at the fourth attempt. Never had this problem before. The car is new and has done around 1500KM on the odo.
During this time of the night the weather in Pune is cold in winters, however today it was not that cold to talk about. Is this somewhere related to this cold weather? Is this behavior normal for the modern diesel car ? Or does it indicate bad fuel ?
The Road had a little banking where the car was parked for 9 hours.
Is this indication of some serious problem coming up in future?
Your inputs would be appreciated.
Thanks in advance!
Cheers,
tush.
tush is offline   Reply With Quote
Old 15th January 2009, 04:22   #2
dreamdiesel's Avatar
Thanked: 55 Times
This problem should not happen with the Swift. Did any of the lights stay ON on the dashboard after the engine started after the fourth attempt? I feel it could be the fuel quality.. And what was the amount of fuel remaining in the car?
dreamdiesel is offline   Reply With Quote
Old 15th January 2009, 10:36   #3
Eddy's Avatar
Thanked: 5,068 Times
Battery trouble perhaps ?
Eddy is offline   Reply With Quote
Old 15th January 2009, 10:51   #4
Jaggu's Avatar
Thanked: 8,681 Times
Doesnt sound right, can be an air in fuel line? I dont think swift d requires more than a crank to start, even when cold the pre heating does a good job.
Old 15th January 2009, 12:13   #5
tush's Avatar
Once the engine started the rest of the lights went off except the seat belt warning light.
I dont understand how its a battery problem. Because the battery was providing enough power for atleast to be able to crank the engine. After the start i drove the car for 11 Km and then turned off the engine and tried starting and it was successfull for the every 3 times i tried testing it.
Yeah you are right. Never had this problem in my first Swift D either. There is atleast more then 10 liters of fuel in the tank.
Is the banking effect on the road got something to do with this ?
Old 15th January 2009, 13:43   #6
trrk's Avatar
Thanked: 13 Times
Heater plugs gone bad?
trrk is offline   Reply With Quote
Old 15th January 2009, 13:52   #7
Thanked: 253 Times
Are there heater plugs in the Swift D? In the Scorpio CRDe, for example, there aren't.
Old 15th January 2009, 14:04   #8
tazmaan's Avatar
Thanked: 1,277 Times
I think it was an one off incident. It can either be due to the fuel quality or air which can happen due to the amount of fuel in the car and the angle at which the car was parked. I suggest you don't worry about it unless it happens again.
All diesel cars normally have heaters the old generation cars used to have a separate switch to activate it before starting and most of the modern cars have it on ignition. It is the sign that looks like a coil after turning on the ignition and which goes off after which you are supposed to start the car. In case of cold climate you can repeat the above process 2 or 3 times before actually starting the car. I learned about this on my Tata Estate have experienced it on my qualis and innova.
tazmaan is offline   Reply With Quote
Old 15th January 2009, 14:14   #9
humyum's Avatar
Thanked: 2,502 Times
If its one time incident, dont think too much into it.Maybe bad fuel,Maybe the cold.If it happens again and again every morning is when you have to worry about it IMO
Old 15th January 2009, 16:13   #10
aerohit's Avatar
Thanked: 623 Times
I would just treat this as a random incident unless problem persists.
aerohit is offline   Reply With Quote
Old 16th January 2009, 03:49   #11
tush's Avatar
Had no issues today. The engine started in the first attempt itself.
Old 16th January 2009, 04:12   #12
vibhu_f430's Avatar
Thanked: 67 Times
Originally Posted by tush View Post
Hello Friends,
tush.
Hay guys,
I did'nt know you had to wait for an engine check light(or something like that ) to turn off before you start the swift !?
I normally start the car with one turn from lock to ignition, then crank the engine , idle for a few min if its a cold start and drive off !
Is there any start-up procedure as mentioned by tush ?
Help
vibhu_f430 is offline   Reply With Quote
Old 16th January 2009, 07:00   #13
Thanked: 146 Times
... There is atleast more then 10 liters of fuel in the tank.
If the car was parked on an unfavourable incline with only 10 liters, it might just be the cause.
HappyWheels is offline   Reply With Quote
Old 16th January 2009, 09:13   #14
Thanked: 146 Times
Originally Posted by vibhu_f430 View Post
Hay guys,
Would really suggest that you keep the car in ON position before cranking for few seconds, till the fuel pump does the customary cycle. This should be like for 15~20 seconds before cranking. And this is for all vehicles.
Old 16th January 2009, 17:00   #15
GSMINC's Avatar
Thanked: 114 Times
Forget about it & enjoy our car.
If it happens again contact the dealer/service centre
GSMINC is offline   Reply With Quote
economy diesel duel: Maruti Ritz DDiS vs Suzuki Swift DDis vs Vista quadrajet aura. s_pphilip Test-Drives & Initial Ownership Reports 25 29th October 2009 09:43
Swift DDiS vs Ritz DDiS vs iKool ? anoovis Hatchbacks 1 21st October 2009 13:09
