Old 16th January 2009, 10:35   #1
Thanked: 285 Times
Default Tire Balancing question
This is about Swift VXI ABS - standard tyres/wheels etc - total 18000 kms.
Last month I did a routine service. At that time, they did a wheel balancing
also. When I took delivery they said that the Wheel Balancing guy said that there is some problem with one of the bearings. I was in a big hurry, so I
didn't get anything fixed then & also didn't get too many details. The service guy said it won't give any immediate problems.
Now I want to get it looked at & fixed.
- Should I go to a service center or to a Tyre Shop?
- Will this be covered by warranty - car is less than 2 years old.
- If not covered by warranty, how much will this cost - ballpark?
- How long can I wait to get this done?
- I don't see any problems, but I am not a good judge - however, another
person who drove my car said it goes slightly to the left - is this because
of the same problem?
Can this be temporarily fixed by replacing whatever wheel is affected by
the spare wheel?
carboy is offline   Reply With Quote
Old 16th January 2009, 11:01   #2
BenjiRoss's Avatar
Thanked: 163 Times
Which of the suspension has a bearing problem. If its the front left and the car drifts slightly to the left then you need to replace quite soon. (Also check tire pressures just to be sure thats not the cause of the drift)
Check the tire and see if there is any unnatural wear in the treads.
Your service manual of the car will tell you if this is covered in your warranty - and there are lots of Swift owners here who will I'm sure enlighten you soon.
BenjiRoss is offline   Reply With Quote
Old 16th January 2009, 11:14   #3
Nikhilb2008's Avatar
Thanked: 6,661 Times
If it's abearing problem, go to your service centre.
However, if you are having a dragging problem, it could also be an alignment problem.
Old 16th January 2009, 11:27   #4
rajatsingh78's Avatar
Thanked: 27 Times
yes..the tyres and bearings are covered under warranty, I got my tyre replaced when it got uneven wear on the treads
rajatsingh78 is offline   Reply With Quote
Old 16th January 2009, 13:47   #5
Thanked: 285 Times
What's the period on the warranty, anyone knows?
Wheel Alignment & Balancing Surprise Tyre & Alloy wheel Section 174 20th February 2018 12:23
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
Are wheel Balancing Weights normal on a new showroom car? Rishi Technical Stuff 4 11th May 2005 10:40
