Thread Tools
Old 21st April 2005, 16:37   #1 (permalink)
Samurai's Avatar
Default How to decide on break-in / running-in period?
How does one decide on break-in period or running-in period for a car? Is it mentioned in the owner's manual. I never read the manual, so I don't know. Or is it just some ballpark number like 2000KMs go below some rpm and some speed?
Odd thing happened while I bought the Acura TL in late 2000. I asked about the break-in period and the dealer told me just drive normally.
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 21st April 2005, 16:52   #2 (permalink)
Rtech's Avatar
How you break in your car depends on how long you want to keep it
Jokes apart, it will be given in your manual. As a rule of thumb, keep the revs below about 3-4,000 (since you have a Baleno) for the first 2,000km's or so, then gradually increase that limit as you put on the miles.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 21st April 2005, 18:15   #3 (permalink)
Jaggu's Avatar
i dont agree to this, modern engines are built with very good tolerance level so runnin wont be mentioned/not required.. usually manual would say, max speed to limit in each gear which in turn translates to not revving engines out / hitting rew limiter in the initial few 100 kms..
ideally you should load the engines in all the gears for proper ring seal to happen and while at it, open up a lil further with every 100 kms or so. hence if you are a ok driver, drive normally...
and running in a car without loading n changing rews will make the engine settle down to a particular rpm which might affect its potential when u open up..
my personal exp with a puny lil 800 is, it also got run in doing highways with ac n virtually raping the engine out.. end result was an amazing engine with equally amazing mileage and power... similar with ikon, gues the initial long hauls when i took the car has worked in to its advantage..
again have done 180 kph on speedo on a baleno altura having run 1 k kms and the owner also ran the initial kms only in the hosur rd highway to electronic city..
only 2 suggestions from my side is, run in to get the balance of the new car and make sure to replace the engine oil at the 1 k odo reading and you should be fine
if u r still confused and want to get confused more read this
http://www.mototuneusa.com/break_in_secrets.htm
happy motoring
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 21st April 2005, 18:19   #4 (permalink)
iceman91's Avatar
hey jaggu you are back!!! no posts in a long time.
well there is no fixed running in duration. once the engine has "freed" up its run in.
running in is required for two things..teh rings and the bearings.
rings set in very very fast.bearings depend on the person who has set it at time of assembly.
i know people who had completed running in 600km for a brand new engine..i.e. rebored redbuilt etc.
while some guys took 5000!!!
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 21st April 2005, 18:26   #5 (permalink)
Rtech's Avatar
Each engine has it's own way to bed in. Certain engines, if not properly run in, can consume oil. I believe the Evo 8 is one such car, that if you don't follow the run in process exactly as specified, it can start using a lot of oil.
__________________
____
Old 21st April 2005, 18:33   #6 (permalink)
Most MPFI cars do not have run-in for engine. Petra does not have run in period mentioned anywhere in the manual. I also checked with dealer and he had no clue about it. He said, run-in is not required for the engine. I believe other than engine, whole transmission system has to lubricate and free up, which would be all set in first 500-1000 Km.
__________________
Drive fast, but drive safe.
RX135 is offline   Reply With Quote
Old 21st April 2005, 18:34   #7 (permalink)
Shan2nu's Avatar
I think 1000 kms of normal sedate driving is more than enuf. There is no fixed figure.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Shan2nu is online now   Reply With Quote
Old 21st April 2005, 18:35   #8 (permalink)
iceman91's Avatar
yes because some of the cars come with pre-run engines
__________________
...91 is back !!!!
Old 21st April 2005, 18:35   #9 (permalink)
Jaggu's Avatar
yup was busy with soe work.. ice there is a defenite diff between factory set engine n re worked and am ONLY REFERRING TO FACTORY SET !!!
yup wild runin whats mentioned on the link i dont suggest (i opeted for a in between run in for my puny ct 100) yeah its all about $$$ he he especially if u urself has paid for the car or bike but if you read through it there are loads of stuff which is very logical and simple..
warm the engine up, run it-load it (NOT OVER LOAD) and rew it higher n higher till u hit the rew limiter at 1k kms
bearings q is also answered in the link (if i remember correct).. let me check n ill post the other links if its not and the first para says it all about this topic.. as controversial as it gets..
__________________
Old 21st April 2005, 18:45   #10 (permalink)
simran's Avatar
This link too talks about similar things: http://www.faqs.org/faqs/autos/toyot...ection-27.html
He also mentions that you need to run-in your brakes as well.
simran is offline   Reply With Quote
Old 22nd April 2005, 10:19   #11 (permalink)
Samurai's Avatar
Ok, now I am thoroughly confused. I am absolutely not sure which running-in method to use. Why can't all car manufacturers provide engines that are pre-run?
Why leave that all important detail in the hands of clueless customers?
__________________
Samurai
Old 22nd April 2005, 10:26   #12 (permalink)
iceman91's Avatar
hey your baleno is a pre-run engine. dont worry follow what jaggu said do not load it initially thats all.else drive peacefully with short bursts once in a while
__________________
...91 is back !!!!
Old 22nd April 2005, 11:02   #13 (permalink)
Jaggu's Avatar
i expected this, DONOT worry, just drive it normal and dont be too gentel or too aggressive with the car
__________________
Old 22nd April 2005, 17:37   #14 (permalink)
speedsatya's Avatar
the mpfi zen manual says that 100kph should not be exceded in the first 1000kms.and hard braking should be avoided for the first 300kms.
as the baleno does 80kph around 2000rpm,it would do no harm in sticking to 2000-3000rpms for the first 1k-2k kms.
also read this
http://209.15.36.61/rdrc/breakin.html
speedsatya is offline   Reply With Quote
Old 22nd April 2005, 23:15   #15 (permalink)
Samurai's Avatar
The dealer did confirm that the Baleno Engine is pre-run, therefore I don't have much to worry about.
__________________
Samurai
Thread Tools
Modify existing rear drum break to disc break in HONDA CITY Gxi. miraauto Modifications & Accessories 14 24th December 2007 00:32
Where to for Xmas break?????? kibi Route / Travel Queries 0 7th December 2007 08:49
Do we really have a 'Running in period' for the new age cars Spinnerr Technical Stuff 2 9th March 2007 09:47
Run in period - How and What to do? LandCruiser Technical Stuff 6 26th March 2006 13:12
Break in period? - Just bought elantra GLS rohanmthr Technical Stuff 24 9th January 2006 20:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
