Old 23rd January 2009, 13:04   #16
star_aqua's Avatar
Thanked: 89 Times
Originally Posted by hrag View Post
I can understand not being able to crank when the engine is running. But when the engine stalls, why should one turn the whole thing off?
thats a mechanical arrangement in the ingnition lock to avoid double cranking. since the key postion are like this
1--> steering lock
2--> accessories
3--> starter
when key is insterted at postion 1 and turned, it will fisrt switch ON the accessories(position 2) and from 2 to 3 is engine cranking. after cranking
the key returns to 2 and now there is lock on postion 3. to release this lock the key has to be put in position 1. hence turning the accessories OFF. this is completely a mechanical arrangement and it cant make out if the engine is stalled.
star_aqua is offline   Reply With Quote
Old 23rd January 2009, 13:12   #17
Saar, crank is always spring loaded AFTER 3, is it not? whether the engine starts or not, the key will come back to 3, not 2. the key can be in position 3 all day without cranking.
But your explanation of the mechanical arrangement makes sense.
hrag is offline   Reply With Quote
Old 23rd January 2009, 13:33   #18
watashi75's Avatar
I am still not clear how the starter motor is connected to the engine flywheel. If I am coasting down in neutral gear with the engine off, will I not be able to crank the engine in this situation? Or do I need to press the clutch and disengage the tranny so that the engine RPM can fall down to 0 before I can crank the engine?
watashi75 is online now   Reply With Quote
Old 23rd January 2009, 13:34   #19
star_aqua's Avatar
Thanked: 89 Times
No Saar. what you say is right which is common in most of the vehicles, but FIAT uses a different setup as what i explained. infact i have this setup from FIAT which came here for immobiliser testing.
Old 23rd January 2009, 14:25   #20
Thanks Vijay - makes sense now. So there is no "IGN" position in FIATs? Haven't lived with one to notice this.
Old 23rd January 2009, 16:32   #21
Thanked: 149 Times
It is not. At least, it is not connected always.
You can, if your ignition system permits you. Ikon/ Fiat owners are facing a safety threat here - since they have to turn the key back to "steering lock" position in order to crank the engine.
Huh? With engine off, engine RPM IS 0.
Old 23rd January 2009, 16:39   #22
watashi75's Avatar
I am sorry about that. I wrote neutral gear when I had a non-neutral gear in mind!
Old 24th January 2009, 00:27   #23
star_aqua's Avatar
Thanked: 89 Times
nope, thats not a threat. you can turn the key back to 'steering lock' position while moving. but never take the key out. the steering gets locked only when at the time you take the key out but doesn't lock when you turn back to 'steering lock' position.
Yes Hrishi, there is no differentation between 'ACC' and 'IGN' postion. both are same.
Old 24th January 2009, 10:40   #24
Thanked: 149 Times
You can't coast with engine off and vehicle in gear. It will start the engine. Else cause serious drive train (gear box, joints, etc) issues.
Old 29th January 2009, 13:51   #25
watashi75's Avatar
Hi BaCkSeAtDrIVeR, I realize I did not ask the question properly! I wanted to know if it was actually possible to crank the engine if it is not at standstill. I found something on the web which answers my question.
So theoretically it is possible to crank the engine even if it is not at standstill, but the engine RPM should not be too high.
Old 29th January 2009, 14:01   #26
sgiitk's Avatar
Thanked: 3,884 Times
Originally Posted by oss View Post
While test driving Linea i noticed that when the engine stalled (the clutch was a bit sharp ), and when i turned the ignition, i couldn't turn it on till i turned the key to complete off position, before turning it on.
Very common in European cars. I had this in my Ford Escort in 1973!
K&N filters & protection from water shazikon Modifications & Accessories 23 22nd December 2011 20:13
Paint Protection poncho Modifications & Accessories 25 4th September 2009 19:14
Paint protection shbhrao Technical Stuff 33 13th November 2007 12:57
Secure seal at yahoo site for protection is available ECM Shifting gears 0 10th September 2006 18:02
Paint Protection treatment rchimni Modifications & Accessories 7 16th March 2005 12:29
