Old 19th January 2009, 20:14   #1
oss
oss's Avatar
Default Starter Protection ?!!
While test driving Linea i noticed that when the engine stalled (the clutch was a bit sharp ), and when i turned the ignition, i couldn't turn it on till i turned the key to complete off position, before turning it on.
I have also noticed this in Logan. A friend tells me that turning the ignition on straight away will reduce the bettery life, though i am not sure about the reason. Why is this forced key turn to off position before turning on the ignition, when the engine stops?
Experts....Pls advice.
oss is offline   Reply With Quote
Old 19th January 2009, 21:19   #2
ImmortalZ's Avatar
Thanked: 312 Times
Linea has this advertised as a feature. It basically prevents the engine from being cranked again when its running. On cars which have highly refined engines, sometimes you won't be able to feel it running. Cranking it again is bad for the stater motor and the flywheel apparently. It has nothing to do with battery life.
Old 19th January 2009, 21:23   #3
nitrous's Avatar
Thanked: 285 Times
My Ford Ikon had this feature too.
Old 19th January 2009, 21:28   #4
yes in fact if it's running and you try cranking, it won't crank but will be the equivalent of revving!
silver_shadow is offline   Reply With Quote
Old 19th January 2009, 21:30   #5
iceman91's Avatar
Thanked: 22 Times
it is a safety feature. Like some cars do not crank unless the brake and in some cases the clutch is fully pressed.
iceman91 is offline   Reply With Quote
Old 20th January 2009, 11:39   #6
Thanked: 103,747 Times
Useful feature. My Classic came with it back in '97! The purpose is to prevent damage / wear & tear to the starter.
How is it a safety feature? Worst case scenario in a car that doesn't have this type of ignition, the starter will crank despite the engine already running.
Old 20th January 2009, 14:49   #7
oss
oss's Avatar
Hmm. I do it often in my Swift Petrol, and realise when the starter motor makes that weird noise of trying to crank the already running engine.
Would this cause severe damage to the starter motor?
Old 22nd January 2009, 16:02   #8
mithun's Avatar
Thanked: 59 Times
Doing this often will ruin the starter motor/solenoid.
Old 22nd January 2009, 16:27   #9
Thanked: 149 Times
Not just the starter motor - the flywheel has a ring / teeth to which the starter motor connects, and these teeth may break off, causing irreversible damage to your pocket.
Old 22nd January 2009, 20:31   #10
Thanked: 52 Times
Ah yes that's a point.
But a question here,
- Starter motor gear assembly disconnects the starter from the engine shaft after the engine is cranked and its running ? so until the engine stalls (i.e the flywheel stops moving) the starter motor should not be allowed to crank the engine.
i don't know how easy is it to implement such a system. Or it's already in place.
I think the "whirrrr" noise is due to the fact that the motor isnt under load and spinning at much faster rates (notice when you crank the speed of the motor is not that much) Also i'd add that running a motor without load is also bad for it.
Xeno is offline   Reply With Quote
Old 22nd January 2009, 21:20   #11
that's what i mentioned earlier in this thread. on one ocassion i had music playing loud with the car in neutral (somehow i forgot this, thinking it was in gear). there i am pressing the pedal and wondering why i'm not moving! (couldn't hear the sound of the engine with the music on). so i try turning the ignition and it didn't give me that jarring sound i hear in marutis but was actually revving!
oh this is an ikon BTW.
Old 22nd January 2009, 22:26   #12
star_aqua's Avatar
Thanked: 89 Times
FIAT has this feature in their cars and trucks(IVECO) from ages. you can even check it out in Palio.
such implementation is already in place. the starter motor is operated by the ECU. the starter is protected from all kinda of scenarios. and also the starter is controlled by the immobiliser. this feature is already there in TATA safari.
and regarding your question, in most of the old vehicles the starter will not be disconnected when you continously hold the ignition key ON. The engine driving the starter motor is prevented with the help of a free wheel mechanism.
star_aqua is offline   Reply With Quote
Old 23rd January 2009, 10:47   #13
Thanked: 149 Times
Here is how a starter motor works.
1. You turn the key (or press the start button, as in some vehicles)
2. A "clutch" inside the motor pushes the rotor of the starter motor into the flywheel cogs, turning the flywheel; which in directly connected to the crankshaft.
3. You release the key / start button, and the rotor is pulled back by spring action, hence the engine is free.
If the rotor is not pushed into the flywheel at all, you will hear a "wheee" kind of sound - like in an electric mixer/grinder or vacuum cleaner. Something is wrong with the "clutch" assembly inside the starter motor. (Clutch is the term I am familiar with - you can name it anything else - :-) )
If you hear a "krr" sound when the engine is NOT working, it means the rotor has not been pushed into the flywheel properly - OR some teeth in the flywheel have broken and the rotor is not engaging the cogs of the flywheel properly. In this case, by simply playing around with the gears, and doing something to turn the engine slightly (releasing and holding the clutch again, etc) will cause the next cog in the flywheel come into place, and cranking the engine again.
If you cranik the engine while the engine is running - you will again hear a krr. sound - the starter motor would not engage the cogs of the flywheel, since even at idle, the flywheel would be spinning faster than the starter motor (I may be wrong on the relative speeds of the engine and starter motor). This uneven match of speeds damages both the flywheel and the motor.
The "double crank" protection - we are discussing in this thread prevents this kind of damage.
Going by description of this mecanism in other vehicles (Ikon and Fiat), I suspect this is achieved through circuitry in the ignition key, and ECU is not in the picture. I am not expert here though. I would love some confirmation on the matter.
Old 23rd January 2009, 10:54   #14
iceman91's Avatar
Thanked: 22 Times
Car is in Gear you crank..what happens???
Old 23rd January 2009, 11:08   #15
I can understand not being able to crank when the engine is running. But when the engine stalls, why should one turn the whole thing off?
hrag is offline   Reply With Quote
K&N filters & protection from water shazikon Modifications & Accessories 23 22nd December 2011 20:13
Paint Protection poncho Modifications & Accessories 25 4th September 2009 19:14
Paint protection shbhrao Technical Stuff 33 13th November 2007 12:57
Secure seal at yahoo site for protection is available ECM Shifting gears 0 10th September 2006 18:02
Paint Protection treatment rchimni Modifications & Accessories 7 16th March 2005 12:29
