Old 20th January 2009, 20:08   #1
Exclamation petrol smell coming during ignition in getz
hello all
our getz is 1.5 years old and has clocked around 8k.Car has been redularly serviced and oil also has been changed within stipulated periods.For the past two days petrol smell has been coming during ignition.I have checked the fuel tank cap and its perfectly closed,but still i could not find a reason for the smell nor there is any leakage below the car.Can somebody suggest wat other
alternatives to be checked for.
1.Its winter in chennai and temperatures around 20-25C-could this be a factor?
2.Can something be wrong with the engine oil?
3.There is no abnormal emission
pls guide on this
thanks
sathya_j2084 is offline   Reply With Quote
Old 20th January 2009, 20:22   #2
iceman91's Avatar
Thanked: 22 Times
is it when the car is running or when you have the ignition on but not yet cranked the engine??
this smell could be in a leak from the engine bay. Check near the fuel filter and inlet manifold area. A pipe might have cracked or be slightly loose.
iceman91 is offline   Reply With Quote
Old 20th January 2009, 20:34   #3
Exclamation
thnx.the smell comes only when the engine is switched on
Old 20th January 2009, 20:40   #4
iceman91's Avatar
Thanked: 22 Times
ok check the engine bay like I said .
Another thing pop the hood ONLY SWITCH ON IGNITION. Check the area I mentioned in my previous post
Old 20th January 2009, 21:21   #5
thnx for ur suggestion.i wud also like to mention that the smell comes from the rear of the car and not in the front.shud i still chek on the engine bay?
Old 20th January 2009, 21:25   #6
Atlblkz06's Avatar
This could be a potentially hazardous - like a punctured fuel line.
It sounds like you're getting the smell right as the fuel pump is turned on?
Get this checked out ASAP!
In my friend's 1 year old car - his fuel line had been vibrating against another part under the hood the entire time and it literally rubbed itself open!
Atlblkz06 is offline   Reply With Quote
Old 20th January 2009, 22:59   #7
iceman91's Avatar
Thanked: 22 Times
did you just fill up the tank?
could be the over flow?
Old 20th January 2009, 23:23   #8
ravi@64bhp's Avatar
I have been getting this same petrol smell in my Wagon-R since long back, may be around one year. Never bothered much as it would happen only when I cranked the engine. Is it really a problem? I have never faced any problem in my car so far.
May be next time I go to ***, I will bring it to the notice of the service person.
ravi@64bhp is offline   Reply With Quote
Old 20th January 2009, 23:30   #9
Thanked: 25 Times
Originally Posted by sathya_j2084 View Post
hello all
pls guide on this
thanks
Its a documented Getz problem. Get your fuel pump checked.
Elito
Elito11 is offline   Reply With Quote
Old 21st January 2009, 11:47   #10
Elito
thnx.if im not wrong,the fuel pump is at the front.but the smell comes from the rear on the right side whereas the fuel tank is on the left side
Old 21st January 2009, 11:51   #11
Akshay1234's Avatar
Thanked: 7,243 Times
the fuel pump is at the rear. thats why u hear a slight noise from the rear for 2-3 secs when you just turn the ignition on.
Old 21st January 2009, 15:28   #12
planet_rocker's Avatar
Thanked: 368 Times
what about the breather pipe? a dirty/clogged breather pipe may cause this
planet_rocker is offline   Reply With Quote
Old 21st January 2009, 16:08   #13
WasavaTyres's Avatar
Thanked: 255 Times
Exclamation
There is a confirmed defect in the design of the fuel pump assy of the getz .Few components of the same are being replaced by hyundai for free when the car comes in for service,My baby had a similiar problem few months ago,the approach to the HMASS at the time was dug up so I did a li'l tinkering of my own. In the pics following this text you can clearly see the leakage above the fuel pump assy which in turn was resulting in petrol vapours being sent into the car. My analysis is that the earlier design had the petrol outlet 'T' at a hgher angle and since it was right below the rear seat it must be buckling under pressure over a period of time,not very sure of this though. I had to drive the car with a leakage for a week as the service guy refused to do shop window sale,asking me to bring the car over,the road was in such bad shape at the time that if I'd driven down there,a lot of other stuff would have come apart on tha car !! So I zeroed down on the troublemaking part and had it shipped from the Pune dealer (Who happens to be a relative of a friend).
Coming back to the HMASS point,my car was replaced with the following parts for free last week :
Part Number Part Description
311160B000FFF Plate Fuel Pump Upper
311130B000FFF Bracket Assy Fuel Pump Upper
WasavaTyres is offline   Reply With Quote
Old 21st January 2009, 16:21   #14
Thanked: 31 Times
My Getz gives a petrol smell once it get started from cold and after that it is fine. I discoved this when i was taking it out the car last weekend but door was open. So i need to come out and close it. Not sure about this as my wife drives it mostly. I will check and update here. May be there is a problem which is discussed here
Elito
What do you meant by documented Getz problem. Is it a common problem with all Getz. My car is 1.5 years old and is in extended warranty
aka_iitd is offline   Reply With Quote
Old 21st January 2009, 20:06   #15
Exclamation
im sorry to ask this,im a novice and i dnt knw where the fuel pump is located.it wud be nice if u can guide me on how to chek the fuel pump,i mean, which part of the car do i open to chek the fuel pump or shud it be done only at the service station?
Hyundai Getz - Ignition coupler bharatbs Technical Stuff 2 1st July 2013 21:51
Hyundai i10 catches fire during ignition! Nan Long-Term Ownership Reviews 64 18th May 2011 15:39
Optra Ignition Coil problem during service at authorised dealer workshop aman_pec Technical Stuff 12 5th October 2009 19:57
Facing problem with Getz ignition wmax Technical Stuff 6 13th February 2008 12:58
HU switches off during ignition zakaaaaasss In-Car Entertainment 38 10th July 2007 13:31
