Old 22nd January 2009, 16:05   #1
mithun's Avatar
Thanked: 59 Times
Question What is Electro Pneumatic Switch ?
In the description it's said that it helps to "Operate Air Horn very much like Electric Horn". So is this a simple switch that helps to change between Electric & Air Horn ?
Roots Auto Products Private Limited - Products - Switches
Old 22nd January 2009, 16:34   #2
badboyscad's Avatar
Thanked: 172 Times
It is just a switch to operate air-horn by the "push of a button"(instead of pressing a lever[like seen in buses]) just like operating a regular electric horn. The horn button will be connected to the electro-pneumatic switch.
When the horn button is pressed,the solenoid in the electro-pneumatic switch is energized, causing the valve connected to it to open, which releases compressed air to the horn trumpets.
badboyscad is online now   Reply With Quote
Old 22nd January 2009, 16:39   #3
Thanked: 149 Times
Hmmm... I have seen such "buttons" near the steering wheels, which in turn control a separate unit hidden away under the hood. I think it is the unit which goes under the hood which is called the "electro pneumatic switch" then?
The "buttion" thingie - have sometimes put it to better use as a push start button. On heavy vehicle, long time back.
Old 22nd January 2009, 17:11   #4
badboyscad's Avatar
Thanked: 172 Times
Yes, the electro-pneumatic switch goes under the hood and close to the air-horn unit.
Old 23rd January 2009, 15:35   #5
mithun's Avatar
Thanked: 59 Times
I've seen cars which is fitted with air horns in which they blow the horn by pressing the steering button like normal stock horns. So that means all those cars are fitted with this switch ?
Anyway, what would be the cost for this switch ?
Indian Railway’s new WDG5 Locomotive, supported by Electro-Motive Diesel GTO Commercial Vehicles 114 3rd November 2017 10:54
Electro Magnetic Radiation and EMF Sensitivity hellmet Shifting gears 13 11th June 2014 20:02
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
Saab electro-cab by Electroengine Dippen The International Automotive Scene 4 10th October 2009 08:24
Will Rossi make the switch to F1? GTO Int'l Motorsport 14 2nd February 2006 18:07
