Old 23rd April 2009, 23:35   #16
Thanked: 152 Times
@HKS ; You see if i get the discs turned they run great for about 100kms then problem starts again.even the recent MGP i got fitted are giving me problems.So i really do not know should i get this set also machined as i finished the last set of discs in around a month by getting them turned on lathe 4 times .
I wish i could help myself.And MASS guy is not giving any warranty so Rs. 2000 down the drain again.
Trust_In_Thrust is offline   Reply With Quote
Old 24th April 2009, 19:01   #17
Thanked: 152 Times
I never knew that a simple task of replacing discs can be so painful and even after spending so much it is not being rectified .So i have decided to live with .Only constraint i have now is i cannot take the car above 70kmph .
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Advice on my old Maruti 800 after suspension and brake overhaul amitk26 Technical Stuff 4 9th January 2009 00:09
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
