Old 31st January 2009, 21:13   #1
androdev's Avatar
Thanked: 2,312 Times
Default why do manufactures charge premium for engines with more CC?
Why such a premium attached to almost identical engines with just few more CC? Am I wrong in assuming that 150CC engine is not that expensive or different compared to 125CC. Just drill a few cm deeper hole in the cylinder ;-)
Similarly 1.9L vs 2.0L in a 4 cylinder engine?
androdev is online now   Reply With Quote
Old 31st January 2009, 21:41   #2
ImmortalZ's Avatar
Thanked: 312 Times
Don't we all wish engine design was that easy?
Here's an inverse situation. An Accord's 2.4L engine, the K24A series, is a much simpler beast when compared to the CTR's 2.0L K20A. The bigger engine makes nearly 70BHP less.
The reason of course, is that the K20A revs to the moon and has one of the most complicated designs ever giving an extremely high BHP/L ratio. Which makes it twice as expensive as a K24 in the engine swap market. Of course, slap on a K20 head onto a K24 block and you suddenly have the best of both worlds (almost).
Engine designs today are not just about cubic capacity. It's about the complicated variable length intake runners, dual camshafts with infinitely variable angles, variable valve lifts - the constellation of technologies that collectively come under the VTEC/VVTi/VANOS umbrella... the list goes on and on and on. These days, it's the head, not the block that differentiates engines more.
Accent's 1.5L vs. the Verna's 1.5L? Octavia 1.9TDI compared to the A4 2.0TDI?
Of course, the whole Bajaj Pulsar lineup is made up of a single engine (save the 220, which is different somehow).
Do Diesel engines generate more Torque than Petrol engines? ex670c Technical Stuff 224 25th November 2013 12:20
Why handling charge is collected from customers? vsk2009 The Indian Car Scene 15 16th June 2012 23:02
Changes you would expect from manufactures on the by BS4 D-Day srikanths1 The Indian Car Scene 1 8th October 2009 12:25
Why car manufactures price cars high in India? DriverR The Indian Car Scene 1 7th April 2007 13:49
