| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BANNED Join Date: Apr 2005 Location: Best City In India Mumbai
| Do Cold Air induction Kits really work in a country like India where in summer there is real hot air flowing through them hence causing power decrese. Whats better a Cold air induction Kit or a Stock Replacement Filter for performance and FE. I asked one dealer to fit FIPK as its known on my City and he told me that there will be power decrese during afternoons as hot air will flow through the Pipe Help Please. Is that true. Which filter is better? |
| | #2 (permalink) |
| BHPian Join Date: Nov 2004 Location: India-Mumbai-Colaba
| hey buddy i'm a stockist for performance parts ..i also stock K&N filter's wel what happens is the universal filter is positioned in such a way that it takes in hot air from the engine bay..so hence a fall in power and FE well on the other hand there are very few people here in india who know the ideal setup for the universal filter with the piping...well if the filter is installed properly...then it can take in maximum cold air ...hence not hampering the power of the car...but in a way it is true the climatic conditions in india...are not very suitable...so it all depends on your choice if you want the box replacement or the universal filter's or the fipk kits...well if you want that one extra bit in performance and are willing to compromise on a little bit of FE...well then universal filter's,fipk kits are the way to go...or else if you cant think out of the box...then yea box replcement filter's definately...that was my bit ..so if you need any other info please feel free to pm me...cheers...!! ![]()
__________________ oVaBoosT - Performance Unleashed...!! |
| | #3 (permalink) |
| BHPian | Hi, Well i'm not in india right now so dunno about that. But let me tell you that i had fitted AEM Cold Air Intake which I'd bought from CARDOMAIN.COM on my friends Accord 1993 2.2L engine. And it really works. I guess you already know the funda behind it... air intake goes all the way till the bottom of the car with the filter place at its tip behind the front bumper. Air below engine / front of car is cooler than air on top of engine (where intake opening of stock car is placed) so we have denser air (cold air = denser air) = more oxygen for the same volume of air that intake sucks in. Air-fuel ratio stays same but oxygen quantity increases= combustion is better improves EFFICIENCY of the car.= generates more grunt with each combustion stroke and also gives more miles per gallon. I've however heard the opposite about the Cold Air intakes in the VW JEtta with 2.0L 2valves /head engine ... generates more power but gives lesser miles per gallon. I wonder why though. other options wud be to "short-ram" which is a really short length pipe..stays on top of engine ... but i dont know how it works... it depends on car to car...short-ram / cold-air intake either may work better for different cars. there's other intakes which give u an option of both... can plug additional tube to short ram to make it cold air intake...aisa working hai bhaiyya... btw..i think it shud work in india too. temperature front/below car always cooler than on top of engine so more denser... most places on this planet i wud guess atleast in india for sure... i will try and post some pics of the intake we installed on the accord in some days in this same thread... the intake cost $220 bhupi |
| | #4 (permalink) |
| hey buddy blaze the air intake kit your talking about is called TYPHOON COLD AIR INTAKE from K&N ive installed a couple of them and yeathe performance and the out come is amazing...well the pipes are heat resistant...also the curves gives on the piping are perfect and hence very very marginal restriction of air flow through the pipe on curves and bends that's perfection redifned..hehe..cheers...!! ![]()
| | #6 (permalink) |
| hey buddy the typhoon cold air induction kit mainly concentrates on cold air intake into your engine system via your throttle body...well the FIPK kit is designed for FUEL INJECTION PERFORMANCE KIT...so it also concentrates on the fuel efficiency part of it...so they are different in their own ways and are installed according to the need of the driver...well i also provide custom made cold air induction kits which comprise of a universal filter and custom made piping which delivers maximum cold air to the engine...the reason being the piping is insulated so the cold air from the intake point till the time it reaches the throttle body remains cold only...well the advantage of chosing this custom piping is the availability of it...as it can be developed for any car ...and its more effictive...so well if you do need any other info..please feel free to pm me...cheers...!! ![]()
__________________ oVaBoosT - Performance Unleashed...!! Last edited by dragger : 27th April 2005 at 18:59. Reason: Spell Check |
| | #7 (permalink) |
| Thanx alot there Dragger. From your post i understtod that Typhhon is for performance and FIPK is for FE? THen whats stock replacement filter for. how are the Typhhon and FIPK different. Can i turbo my new City? |
| | #8 (permalink) |
| Newbie Join Date: Apr 2005 Location: I unno
| Have you considered NX's N-tercooler kit? It's a nitrous set up for your intercooler and sprays N20 on the Intercooler making it much colder than normal, resulting in colder denser air with more O2, allowing for better combustion and thus more hp. In India where it's considerably warmer I'm sure this could come in quite handy. At the push of a button you have 5-10 more hp (NOT from a nitrous kit, from the cold air as a result of colder intercooler). Anyway, something to think about, although it will probably have to be shipped from North America.
__________________ |
| | #9 (permalink) |
| hey buddy montoya the FIPK kit isnt only concentrating on fuel efficiency it also gives you a raise in power...as it is a conical filter and hence larger volume of air intake ..hence more power...wel the box replacement filter gives absolute fuel efficiency with marginal power raise as the air intake volume remains the same only difference is the air flows freely compared to the stock filter...cheers...!! ![]()
| | #10 (permalink) |
| Well about the new city if your reffering to the NHC then i don think the stock engine is capable of taking any boost...on the other hand a lot of other aspects of the car have to be taken into consideration which i dont think is possible in the case of the NHC..well if we do work on the engine chamber and the pistons and the head and valves may be then TC'ing the car is possible..but still it wouldn't be an absolute success...i would advise sumthing like a lancer or the OHC..if you want to turbo...anyways buddy if you need any more info pm me...cheers....!! ![]()
| | #12 (permalink) |
| BHPian Join Date: Mar 2004 Location: bangalore
| you know gordan ive always thought about that too..but i wanted to stack it in the pipe that guides in air from outside and directs it to your conical filter.
__________________ AAKGC- Activist Against Killing a Good Car |
| | #13 (permalink) |
| Senior - BHPian | well grdon and anoops it does help..but for how long??? also the hp increase is not that phenomenal....exact same thing was being discussed by psycho and me...need to actually try it out since i have certain doubts about it...will keep you updated
__________________ ...91 is back !!!! |
| | #14 (permalink) |
| hey ice, iam talking only in a drag scene..not going to be viable on an everdyday ride....but during a drag air filtered through dry ice will be a lot more colder and denser, it should make a diff.
__________________ AAKGC- Activist Against Killing a Good Car Last edited by anoops : 28th April 2005 at 12:18. |
| Thread Tools | |
Similar Threads | ||||
| Improving the Cold Air Intake. | wanderernomad | Modifications & Accessories | 9 | 25th August 2008 14:15 |
| CAI will suck only cold air: even if sucking in air just next from the engine :-) | khan_sultan | Street Experiences | 19 | 30th June 2008 09:29 |
| Diffrence between an ordinary cold air intake and a ram air intake?? | Vys De BlUR | Technical Stuff | 24 | 1st April 2008 12:59 |
| Best air filter or cold air intake for Skoda RS | Kartik9500 | Modifications & Accessories | 9 | 7th February 2008 02:43 |
| DIY cold air intake system | kutlee | Technical Stuff | 2 | 6th September 2006 10:36 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
