Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 4th February 2009, 11:30   #1 (permalink)
revhappy's Avatar
Default Left leg position while driving
Hi Guys,
Earlier I used to drive a 2002 MPFI zen, it has a low seating position and hence I would pull the seats back and while driving, I would always keep my left leg over the clutch, without pressing it. I would only press while changing gears.
Now that I have bought my Indica Vista, it has a high seating position and I continue to leave my leg on top of the clutch. This cause severe pain to me after driving for about an hour or 2 in the city.
Hence I wanted to ask you guys, if you also do the same thing or keep the left leg on the floor and only while changing gears would you keep you leg on the clutch?
Please advise.
Cheers,
Nitin
__________________
Vista TDi Aqua - Dec '08 - 7000 kms
Zen VXi - May '02 - 45000 Kms
revhappy is offline   Reply With Quote
Old 4th February 2009, 11:39   #2 (permalink)
esteem_lover's Avatar
I guess I wouldn't have that problem since i always take my foot off the clutch when i am not shifting gears.
Solution would be to get a dead pedal fixed beside the clutch pedal & rest your foot on that while not shifting gears.
__________________
"Keep your friends close, Keep your enemies closer"
Old 4th February 2009, 11:43   #3 (permalink)
I have clutch foot rest in my Palio 1.2, just check at the extream left side of the clutch if Vista has the same.
__________________
Palio 1.2 ELX
Pulsar 220 Dts-FI (Sold)
Kinetic Sym Flyte
Pulsar 150 Classic (Sold)
Honda Unicorn Classic
Kinetic Blaze (Sold)
pawan_pullarwar is offline   Reply With Quote
Old 4th February 2009, 11:46   #4 (permalink)
jango's Avatar
Post
While driving around i do not rest my foot on the clutch lever. I place my left foot on towards the left of the clutch lever ( On the floor )
I place my foot on the clutch lever only when i need to change the gear or when i am in heavy traffic !!
__________________
Wounds Heal & Bones Set DRIVE FAST !!
jango is offline   Reply With Quote
Old 4th February 2009, 11:54   #5 (permalink)
deadguy25's Avatar
Originally Posted by revhappy View Post
Hi Guys,
Please advise.
Cheers,
Nitin
Hi Nitin,
It depends on your comfort level, your reflex time, etc. While trying out the various positions of the left leg, ensure you are able to get to the clutch with the minimum response time.
I keep my leg on the floor.
__________________
Deadguy
I fly low
deadguy25 is offline   Reply With Quote
Old 4th February 2009, 13:12   #6 (permalink)
watashi75's Avatar
There is rarely any situation where the left leg needs to respond fast. It is the right leg which should handle all the emergency situations. If the left leg is on the clutch, in panic situations the clutch might also get pressed and disengage the engine, which is not good.
It is best to keep the left leg on the floor, though it may take time to get used to it.
watashi75 is offline   Reply With Quote
Old 4th February 2009, 13:24   #7 (permalink)
siddartha's Avatar
get an "auto clutch " for your car , then you can keep your left leg where ever and how ever you want .
__________________
warm regards
siddartha
(05 RS, 99 city 1.3, 97 zen,94 m1000,89gypsy,85mvan,78 padmini,64 herald,36 austin7,95 shogun,82 bsa bond)
siddartha is offline   Reply With Quote
Old 4th February 2009, 14:16   #8 (permalink)
pulsar56's Avatar
Won't that be an expensive option on a manual car? If not, can you please provide some details regarding the same?
Don't even keep your leg on the clutch even if you are not pressing it! It might so happen that you are clutch riding even without realizing and will lead to early clutch wear!
__________________
Turn right to go left! Guess what? I tried it, and you know what? This crazy thing happened - I went right! - McQueen
pulsar56 is online now   Reply With Quote
Old 4th February 2009, 14:23   #9 (permalink)
siddartha's Avatar
i think there is a thread somewhere which talks abt this , just look around and as far as i know its not expensive, its just a switch which electromechanically actuates the clutch.
__________________
warm regards
siddartha
Old 4th February 2009, 16:32   #10 (permalink)
revhappy's Avatar
Thanks for your responses guys!
I will start practicing the placement of foot on the floor and see how it goes.
Cheers,
Nitin
__________________
Old 4th February 2009, 16:44   #11 (permalink)
Any pics of this modification. How much will it cost and where in Noida I can get it done.
I am also facing same issue in my chevy spark!!
__________________
Rgrds
sparkguy
sparkguy is offline   Reply With Quote
Old 4th February 2009, 17:39   #12 (permalink)
A.R
A.R's Avatar
I put my foot on a small square plastic thing on to the extreme left with a small red light blinking when I switch on/off the car. I think its the Nippon security system. Not bad I think?
__________________
Success is No Accident; People do not lack Strength, they lack Will
A.R is offline   Reply With Quote
Old 4th February 2009, 18:55   #13 (permalink)
Bit strange that your security system sits alongside the clutch leaver. In my spark its concealed inside the dash.
__________________
Rgrds
sparkguy
Old 4th February 2009, 19:30   #14 (permalink)
pranavt's Avatar
The Santro used to have a small rest next to the clutch so it was very convenient to keep my left foot there. In the OHC, I just keep it to the left of the clutch, mostly resting on my heel.
Old 4th February 2009, 19:52   #15 (permalink)
trrk's Avatar
For the auto clutch thing, please take a look at the following:
http://www.team-bhp.com/forum/modifi...-automate.html (anyone used automate?)
http://www.team-bhp.com/forum/access...ch-review.html
The easier and cheaper would be to get the habit of putting your left foot on the floor or to fix a dead pedal!
__________________
Rajesh
-Marina LS, Oct 05, 61918 (63574) kms, 13.97 kpl, 44km/day
-City CVT, Sep 07, 40473 kms, 13.29 kpl, 53 km/day
trrk is offline   Reply With Quote
Thread Tools
Interesting facts about Left Side or Right Side Driving kreddy Street Experiences 8 25th May 2009 17:31
Driving Position / Where to hold the steering wheel! Torque-ative Technical Stuff 56 4th July 2008 17:58
Driving Position of Cars herculesksp The Indian Car Scene 9 24th October 2006 03:20
The Cars with the Best & Worst Leg-Room in India mithun The Indian Car Scene 5 10th August 2006 11:43
Steering Position? BUSA Technical Stuff 8 6th March 2006 12:36
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
