Old 19th February 2009, 19:10   #16
ariendj's Avatar
Thanked: 79 Times
i have noticed for many days now that the buzzing sound appears only when the engine is revved hard.this was never the case before.what could be the issue??
i had expected the sound to go with use but its been weeks and still no change!!!
ariendj is offline   Reply With Quote
Old 20th February 2009, 20:08   #17
km120's Avatar
I suspect that to be gear box issue . I am not sure and would like someone to correct me
km120 is offline   Reply With Quote
Old 21st February 2009, 16:50   #18
Thanked: 658 Times
what buzzing sound, revving when in motion or just in neutral gear.
If the sounds comes when the car is stationary, gearbox is out, check something else.
Old 21st February 2009, 20:15   #19
ariendj's Avatar
Thanked: 79 Times
the sound is more like a wheezing type.and it is present when i press the accelerator pedal when stationary and when i high rev on any particular gear.it feels like as if the car doesn't want to be revved higher than normal which is totally unlike the engine before.
Old 21st February 2009, 23:45   #20
Thanked: 658 Times
I don't suspect the GB, because when you are stationary you are pressing the clutch and GB is totaly disengaged. It might be a case of loose bushes of gear lever assembly.
PS: you did changes your flywheel right.?
Old 22nd February 2009, 00:26   #21
humyum's Avatar
Thanked: 2,187 Times
I dont see in the part list that he has changed the flywheel bearing.Only the clutch bearing was changed and you should be completly pissed with them for not changing the flywheel bearing as for this one bearing the entire GB will have to downed again.
Go to the same MASS u got this job done from, and ask them to check where exactly the sound is coming from.
Also the wheeshing sound can come from the alternator bearing too.
Old 22nd February 2009, 09:09   #22
Thanked: 252 Times
Hope you've ruled out the basic things like air filter and belt tensions.
Has the fuel been adjusted for greater fuel economy?
Engine not willing to rev while stationary seems to point to a problem not related to the clutch plate or gearbox!
BTW, is this a carb model?
Old 22nd February 2009, 16:02   #23
Thanked: 658 Times
Its definitely a Carb model. As he quoted its a '98 model
Old 22nd February 2009, 17:40   #24
SS-Traveller's Avatar
Thanked: 10,778 Times
... buzzing sound appears only when the engine is revved hard...
I've noticed a similar whine on many carb M800 engines - it's usually an intake manifold whistle, heard more often with a fresh air filter in place - completely harmless. Also likely to be a slipping belt. Does your car have an AC?
Do you mean the whining/wheezing sound makes you stop revving the car, or the revs don't rise even if you keep the accelerator floored?
Old 22nd February 2009, 21:58   #25
ariendj's Avatar
Thanked: 79 Times
the car has not been tuned for any better adjustments.the engine can be revved as always and no stopping it but that sound increases as i floor the pedal(accelerator) more.
its a '99 model
its just teh sound that annoys me,and its very audible to people around.
the sound rises when the accelerator is floored.
Old 23rd February 2009, 12:32   #26
Thanked: 252 Times
...the engine can be revved as always and no stopping it but that sound increases as i floor the pedal(accelerator) more.
its a '99 model
its just the sound that annoys me,and its very audible to people around.
Your posts are confusing!
So the engine can be revved freely, but there is that sound! Right?
Does the sound come at same level in neutral at standstill and with gear engaged and moving?
Old 23rd February 2009, 15:04   #27
Remove the air filter and rev to check if the noise is gone or not. If not, remove the water pump drive belt and rev once to check. Don't rev more without the belt, or your engine will overheat.
My guess is it's either a resonance from the air filter, or bearing noise from the water-pump/alternator bearing. Shouldn't be too difficult to diagnose.
Old 24th February 2009, 07:16   #28
ariendj's Avatar
Thanked: 79 Times
sorry to get it all into a confusing state.
ya as you mentioned the sound is same when revved in neutral and also when the gear is engaged.the sound keeps increasing as the engine is revved up higher
ya il try that too.thanks
Is this a clutch plate Problem???? The Stig Technical Stuff 15 2nd April 2012 09:29
Ford Endeavour's got a clutch prob within 6 months..can i claim for a warranty ?? stanjohn123 Technical Stuff 39 10th September 2011 17:03
Clutch Plate change for Matiz SCH Technical Stuff 4 10th May 2009 08:04
Bullet Mag-wheels (size = 19") and 4-plate clutch assembly for sale wanderlustindia Shifting gears 0 27th December 2007 17:15
Is my clutch plate damaged? johy Technical Stuff 15 25th April 2006 07:20
