Old 6th February 2009, 13:08   #1
Exclamation OPEL ASTRA Alternator
Hi All,
Need all of your expert advice on a peculiar problem plaguing my ASTRA 1.6 1997 model. The symptoms are as under;
1. The hedlights and instrument lights are working like that of a scooter! Which means, when the RPM exceeds 3000 RPM, the lights brighten up and automatically start dimming after sometime!
2. The battery gets automatically discharged(Its a new Exide battery and there's no problem with the battery perse)
3. Roughly 8-9 electricians would have had a look at the alternator and allied systems and fiddled with the system including checking leakages etc which they never found or could rectify. This includes Metro Motors, a GM dealer where service is otherwise horrific.
4. Is it a problem with the alternator? If so, shall I get it changed? The alternator costs a bomb anyways!
sandeep.mishra is offline   Reply With Quote
Old 6th February 2009, 13:52   #2
siddartha's Avatar
Thanked: 24 Times
dont replace with a new one right away , get the alternator overhauled, check the winding, get the rewinding done if reqd, replace the carbon brushes .
siddartha is offline   Reply With Quote
Old 6th February 2009, 15:59   #3
Thanked: 149 Times
There is (rather, ought to be) something called a "regulator" - an electronic circuit (usually in a sealed unit). Insufficient charging, random charging, overcharging, inadequate output, etc. are symptoms of regulator malfunction too. Ask the roadside auto-electrician to check the regulator.
Opel Astra Club or Opel Corsa bsashwin Sedans 2 11th July 2006 17:34
Opel Astra Automatic Wanted haryan Shifting gears 17 19th November 2004 02:57
Query regarding Opel Astra. nisweth Technical Stuff 4 17th November 2004 12:36
Opel Astra HPC amit The International Automotive Scene 13 27th September 2004 10:42
Opel Astra GTC amit The International Automotive Scene 7 21st August 2004 13:57
