Old 9th February 2009, 18:30   #1
MB-Sting's Avatar
Default Cabin noise at cruising speed (120) excessive or normal
Hi
When I drive 110 on the speedo the car is pretty quiet inside but once I go past 120 (2500rpm) the engine noise about doubles and you can almost not have a normal conversation in the car. Is this normal for the Scorpio suv or can something be done.
Note that the previous owner removed the CAT and put in a straight pipe + original silencer box. Could this cause the noise or is it just normal engine noise?
I cannot decide if it is engine or exhaust noise.
MB-Sting is offline   Reply With Quote
Old 9th February 2009, 21:48   #2
Thanked: 89,068 Times
That's the most likely culprit. That annoying sound is exhaust resonance / drone from a badly designed exhaust. Switch back to stock.
Old 10th February 2009, 00:05   #3
Atlblkz06's Avatar
I agree with GTO. Unless you have an intake/cam or something done to the car, I'd go back to stock. Your post is a bit confusing though. Straight pipe = no silencer. Simply removing the cat shouldn't lead to a huge in crease in sound levels.
Atlblkz06 is offline   Reply With Quote
Old 10th February 2009, 14:57   #4
Samir Taheer's Avatar
Thanked: 60 Times
Looks the cars only been De-catted. If the exhaust was the culprit, i would'nt have thought there would be that much of a difference between 110 and 120. Could it just be worn rubbers? The cabins not as well sealed as it used to be and he's just hearing excessive tyre noise and wind noise + the engine?
Samir Taheer is offline   Reply With Quote
Old 12th February 2009, 11:44   #5
Atlblkz06's Avatar
Engine "drone" is when the engine and the car create a standing resonant wave. This is very sensitive to the engine RPM since that's its source of energy to build up. this is probably why its so sensitive to speed.
Thats my take anyway.
Rumour: Renault stops Kwid production due to engine problems (excessive noise) Chillout The Indian Car Scene 13 19th May 2016 21:06
Whats your comfortable cruising speed? Shan2nu Street Experiences 212 6th March 2013 12:47
Excessive Tire Noise dhinchak Tyre & Alloy wheel Section 16 11th January 2013 11:30
Cabin hot but temperature gauge normal paish Technical Stuff 10 9th April 2010 14:45
Cabin Light Switches On When Engine Cranked ; Normal ? lambuhere1 Technical Stuff 3 22nd July 2008 14:57
